Using a pedal switcher and MIDI
Posted: Tue Oct 08, 2019 9:12 am
by GADonis
I'm looking into putting together a "no expense spared" pedal board, well, mostly no expense spared. I'm thinking of getting a Pedal Pad board and using a Boss ES-8. The Pedal Pad has an option to build in a MIDI connector. I'm trying to determine how many MIDI connectors I would need built into the Pedal Pad. I've never used MIDI before so I just want to double check my thinking. To use the ES-8 to control channel switching and solo boost in this arrangement I'll just need to run a MIDI cable from the switcher to the "inside" MIDI connector of the board and then run a MIDI cable from the "outside" MIDI connector of the board to the MIDI IN on the amp, correct? No need to connect anything to the MIDI out/thru of the amp?
Re: Using a pedal switcher and MIDI
Posted: Tue Oct 08, 2019 3:49 pm
by ned
Sounds about right to me. However I am unfamiliar with the Pedal Pad.
Posted: Wed Oct 09, 2019 3:47 am
by stephen sawall
Need more information.... Who makes the Pedal Pad you are using ?
But it looks right from the info you gave.
Posted: Wed Oct 09, 2019 1:22 pm
by GADonis
This is the board I'm looking at
https://pedalpad.com/shop/products-buy- ... category=0
He has options to build in various input/output jacks into the sides of the boards case. I'm thinking qty. 4 1/4" jacks for guitar input, output to amp, and FX loop out and in. Also thinking that one midi jack would let me use the ES-8 to also control the amp along with the delay and modulation pedals.
I'm really just trying to figure out if I need more than one built in MIDI jack in the board.
Posted: Mon Oct 14, 2019 11:21 am
by RobbieBoyette
You don't need more than one out midi.
I'm using a G System with my TC 50 and the out midi on the G System is all I need.
The TC 50 has an out/thru on it if you need midi control back by the amp as well.
Posted: Fri Oct 18, 2019 12:16 pm
by GADonis
Thanks. That is what I had figured. I went ahead and bought the switcher and one midi cable last week just to start learning how to set it all up. The manual for the ES-8 leaves something to be desired, but it wasn't too hard to get it up and running.
Today I bought the rest of the stuff. Adding it all up maybe I should have just bought a Helix. I've wanted a nice "one button" pedal board for some time and selecting the bits and pieces and putting it together is half the fun. Okay, maybe 30% of the fun. Of course I may be singing a different tune when I get elbow deep into soldering the patch cables.
