It is currently Wed Jul 18, 2018 8:48 pm
Post new topic Reply to topic  [ 82 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
 Post subject: Re: TC50 Tube discussion
PostPosted: Thu Sep 07, 2017 5:17 pm
Triple Recto
The SE Voodoo VR1 ribbon mic and cloudlifter came in a day early.... was expecting Friday for delivery. No amp to record though as that subject is off for repair. Time to break out the JP-2C and run a comparison to the Roadster and the Mark V. I will not flood the results here perhaps in another forum. Just not in the heavy metal mood though.... but I can get there once I power up the amp in no time.
PostPosted: Fri Sep 08, 2017 1:18 pm
I am finally going to give the 5881s a shot. I had put the stock EL34s in for this week and the opportunity to hear the amp roar fell through. So, I will be pulling those and running the 5881s instead. Will post my results after next week.
__________________
TC-50, Electra Dyne, Mark V, Road King I
Mostly Fenders with Duncans
EVM, Eminence, and WGS speakers
PostPosted: Fri Sep 08, 2017 6:12 pm
Triple Recto
Don't forget to set the bias switch to 6L6...... :roll:
I thought they sounded great in person. More of a full 6L6 tune than the STR440's. Those actually sound better pushed but the 5881 sounded great at all volume levels.
PostPosted: Tue Sep 12, 2017 12:00 pm
I am always extra careful before I power up my TC50. The speaker off switch can so easily be hit I make sure everything is where it should be on the back panel before I hit the first power switch.
I read somewhere that Mesa's 5881s are actually Sovteks. I have Mesa's in mine at the moment. Will get to hear them over the next few days.
__________________
PostPosted: Tue Sep 12, 2017 6:35 pm
Triple Recto
I would also think the 6V6 are too. EL34 are EHX tubes. All made by the same company in Saratov, Russia; Reflector corp. aka: Sovtek Mullard, Svetlana [not the =c= tube company] Tung Sol, and what ever brand or trade name that has been purchased by New Sensor and now brokered by them)
The Mesa 6L6 STR 440 is a Chinese tube (Sino or Shuguang, actually they are the same manufacturer or not, hard to tell ) generally resourced though Ruby tubes.
PostPosted: Mon Sep 18, 2017 2:27 pm
I'm not sure if it was the 5881s or the Nova System I had in the loop, but I had to really crank my TC50 at my gig over the weekend - like 2/3 to 3/4 full volume on both the channel master and the global master. I put the stock EL34s back in for now, but will need to further test with the Nova System and see if I need to tweak it for it's input and output signal. I've used the effects unit with another amp and had no volume issues whatsoever. Tone-wise, meh. I still prefer the 6V6s or stock EL34s. But, that's just my ears - and all through an EVM12L. While there was some similarity between the 6V6s and the 5881s, I still find the 6V6 tone to be more lively, especially on CH1.
__________________
PostPosted: Thu Dec 28, 2017 6:47 pm
Triple Recto
Must be the nova system (one would hope anyway). Not sure where the amp runs exactly with 6L6 or 5881 but it does seem a bit softer than the EL34. Still it should be much louder than the 6V6.
I am really oogling the TC-100, having a quad of 6V6 may be too good or not good at all. will have to see when that time comes.....
