It is currently Sat Feb 24, 2018 8:38 am
PostPosted: Thu May 18, 2017 8:57 am
Hey guys,
Sorry if this is a noob question, but I'm having a difficult time trying to get a set of headphones to work out of my TC-50. When I plug in the headphones, nothing comes out. The headphones I'm using are a garbage unit: Audio Technica ATH-M30. I'll upgrade if I get it to work. This is what it looks like at the back of the amp:
Is there a setting that I'm not "activating" in order to get the headphoens to work? Do I need to get a different set of headphones? Or is it more likely that it's an issue with the amp? Any help in figuring this out would be much appreciated!
"Strength does not come from physical capacity. It comes from an indomitable will."
-Mahatma Gandhi
http://www.facebook.com/mytochon
http://www.bandpage.com/mytochon
PostPosted: Thu May 18, 2017 1:47 pm
I have yet to try my headphone jack, and I found nothing in the TC's manual to suggest this, but in your photo, you have the speaker set to "on." Have you tried with the speaker set to "off?"
One thing the manual DID cover is that the CabClone DI won't work when headphones are plugged in.
__________________
TC-50, Electra Dyne, Mark V, Road King I
Mostly Fenders with Duncans
EVM, Eminence, and WGS speakers
PostPosted: Thu May 18, 2017 9:45 pm
Ahhh.. yes. I'll try that and report my findings. Thank you!
-Mahatma Gandhi
PostPosted: Sat May 20, 2017 12:09 am
Unless they fixed it on the TC, the CabClone's headphone out is not so good. You'll probably want to run it into a headphone driver or small mixing board to drive headphones properly.
Mini Rectifier blue LED
2x Recto 2x12 Vertical
PostPosted: Sat May 20, 2017 3:21 pm
Good call. It works now. Thanks you!!
The sound quality isn't garbage at all, but it leaves much to be desired. But then again, there's a good chances that it's because of my cheap POS headphones.
-Mahatma Gandhi
