Hi guys.
I'm trying to get my FRACTAL AX8 to control my TC50 via MIDI.
I read the manual how to setup the presets over the amp but it doesn’t work as it should.
AX8 MIDI channel is "1" and the TC dial is set to "0" = channel 1 and I can see the LED lit when I press any of the AX8 switches so MIDI is running ok.
When running the procedure of setting memory for the presets, I end up that only the last function / amp channel I have selected, Is the one that react / working via MIDI from the AX8 for example, I tried to set amp ch1 to be active on preset 1 + 2 over the AX8 and then set ch2 for preset 3 and Chanel 3 for preset 4 but only ch3 reacts as it was the last channel I stored.
If for example the last channel I tried to store is ch2, only this ch2 gets triggered vial midi and no other do.
What am I missing?
Thanks.
What am I missing?
Thanks.
