case for JP-2C footswitch
Discussion area for the new (and first) Signature Model from Mesa Engineering.
rxb216
Post by rxb216 » Mon Jun 11, 2018 6:22 pm
Friends,
Just scored the last JP-2C LE from Humbucker's and am really excited.
Had a quick question on the footswitch...
All my previous Mesa amps came with a padded footswitch that Mesa no longer seems to include with their amps now.
I was looking for a case for the JP-2C footswitch and came across this:
https://www.casesbysource.com/product/s ... 20-scs-320
The footswitch is listed at:
2.5" H x 10.125" W x 5.5626" D
The case's internals are
3" H x 10.6" W x 8.3" D
The ~3" extra depth could be solved with some foam I guess, but I wanted to ask what others are using to store their JP-2C footswitch. Maybe there is something out there that has a better fit...Thanks...
JP-2C LE
Road King II V2
Mark V
Triple Rectifier 3-Channel (2000)
Rectifier 4x12 Oversized Straight
Rectifier 4x12 Oversized Slant
Rectifier 2x12 Compact
Roadking 2x12
bandit2013
Triple Recto
Re: case for JP-2C footswitch
Post by bandit2013 » Wed Jun 20, 2018 6:05 am
If the case is large enough, you can shove the cable in with it (assuming it fits). Looks like a good solution. May even pass this on to the TC owners too, footswitch is the same size and those amps do not come with a case for the footswitch (well the heads anyway, not sure about the 50W combo though). I see on the site you can have it customized (I am assuming that means embroidery on the case?). Cool, thanks for sharing. 8)
