Midi Controller
Discussion area for the new (and first) Signature Model from Mesa Engineering.
Mrhiwatt
Midi Controller
Post by Mrhiwatt » Thu Feb 08, 2018 6:47 pm
Hi,
I am back to using pedals for effects on the jp2c. Do any of you have suggestions for a midi foot controller so I can turn of the effects loop shred, reverb, etc. I was unable to cure my ground loops with my Boss es-8. but miss its midi capabilities.
MrHiwatt
Jp-2c Mesa 2x12 cab with V30
FlyingBlue
Re: Midi Controller
Post by FlyingBlue » Fri Feb 09, 2018 11:33 am
It’s likely overkill for what you want to do, but I use a Rocktron MIDI Raider setup with switches 1 - 5 to switch presets on my effects processor (as well as switch channels on the JP) and use the other 10 switches as instant access switches. I use 1 each for fx loop, shred, each EQ and reverb, then I use the rest to grab delay, chorus, reverb and pitch from my FX, the last IA switch I use to bypass the fx.
tbguitar55
Re: Midi Controller
Post by tbguitar55 » Sun Feb 11, 2018 1:06 pm
These guys make some great SMALL footprint pedals! I also use a One-Control Basilisk controller. You'll need to determine if you require CC or PC signals to control your devices.
http://www.disasterareaamps.com
tb
Lokair
Re: Midi Controller
Post by Lokair » Fri Feb 23, 2018 9:07 pm
Not a perfect solution , but I use a voodoo lab ground control plugged into the footswitch out with a 7 pin midi cable. As the foot controller is just a midi switch and the two extra pins provide power for the ground control. I use it as 4 scenes or programs and 8 cc switches so I can ala carta my sounds. For example program 1 is channel 1 dry (nothing added) then I can pick up any thing available to channel one using the cc control, program 12 is channel 2 with efx loop on , reverb on and eq 1 . Then if I want I can change eqs or shred and turn off anything I do not want at any time. One problem(which does not bother me) is the CC lights do not automatically come on as I switch programs(i cured this for me by naming the program as the song its being used in).
Lok
