JP2c bedroom volumes?
Discussion area for the new (and first) Signature Model from Mesa Engineering.
T85
Post by T85 » Wed Jan 03, 2018 7:09 pm
Hi all. Im new here and I have a question I was hoping some one could help me with. I may have the chance to get the JP2C soon but I was wondering how it performs at low volumes when it comes to modern high gain. It doesnt have to be whisper volumes but low enough to keep form blowing up the house or pissing the wife off. It'll be played through a Recto 2x12 if that helps any. Any input would be appreciated, thanks.
UpNorthMark
Re: JP2c bedroom volumes?
Post by UpNorthMark » Wed Jan 03, 2018 8:44 pm
I actually have mine on a 2x12 Mesa cab and play in the house without bothering the wife at super low volume and it sounds good. I use the shred feature at super low volume, now at about 11-12 O’clock on the volume you’ll get a completely different feel and it’s absolutely incredible. For me I was running a Mark V 25 for low volume stuff and actually sold it in favor of the JP2C since it didn’t do low volume any better. You’ll have to twist your eq settings around a bit to accommodate the lower volumes but it’s quick and easy. Best of luck.
Mark
Current Amps:
Mark II C+ DG
JP-2C
Mark V:25
& Lots of Cabs!!!!! (all Boogie)
T85
Post by T85 » Wed Jan 03, 2018 9:30 pm
UpNorthMark wrote:I actually have mine on a 2x12 Mesa cab and play in the house without bothering the wife at super low volume and it sounds good. I use the shred feature at super low volume, now at about 11-12 O’clock on the volume you’ll get a completely different feel and it’s absolutely incredible. For me I was running a Mark V 25 for low volume stuff and actually sold it in favor of the JP2C since it didn’t do low volume any better. You’ll have to twist your eq settings around a bit to accommodate the lower volumes but it’s quick and easy. Best of luck.
Mark
AWESOME! thanks! Thats what I was hoping to hear. I plan on using a boost to but the shred function may be enough.
jmontgomery
Post by jmontgomery » Thu Jan 04, 2018 2:19 pm
My MarkV35 doesn’t really open up until the master is at least 9:00, which is loud. I’m using an attenuator at home and I’m getting excellent low volume tone. I’m sure you could do the same with a JP2.
Jeff M.
SamuelJ86
Post by SamuelJ86 » Fri Jan 05, 2018 1:12 am
How amps perform at bedroom volume is very subjective. If that's what you're used to or if you seldom ever play at loud volume and it's your first mesa/tube amp and you're really pumped about it, it probably sounds awesome. If you mostly play at loud volumes you probably don't think it sounds too good at bedroom volume. You can play it at bedroom volume and its passable, but it is exponentially better loud.
If it were me, and you told me I could only play my JP2C at bedroom volume, I would sell it and buy a fractal. Your mileage will definitely vary.
Also, for what it's worth, the mark v 90 watt is much better at bedroom volume. Haven't played the little ones enough to have an opinion.
PRS 408
Les Paul Custom 08
Edwards Alexi
Mark V
JP2C
T85
Post by T85 » Fri Jan 05, 2018 10:55 am
SamuelJ86 wrote:How amps perform at bedroom volume is very subjective. If that's what you're used to or if you seldom ever play at loud volume and it's your first mesa/tube amp and you're really pumped about it, it probably sounds awesome. If you mostly play at loud volumes you probably don't think it sounds too good at bedroom volume. You can play it at bedroom volume and its passable, but it is exponentially better loud.
I rarely get to play at loud volumes but it does happen sometimes .I've never had a Mesa Boogie amplifier before, though I've been wanting one for years. I played through a roadster years ago for maybe about 10 minutes but that was it. I got the evh 5150 III lunchbox as my first tube amp and I'm really impressed with it but since I have the chance to get something this high-end, I don't want to pass it up. If all else fails, I guess I could always just get an anttenuator.
SamuelJ86
Post by SamuelJ86 » Sat Jan 06, 2018 2:27 am
If you really want the JP2C, and you've done your research and slept on it, then go for it. Life is short and there is nothing like having the best. Learn for yourself if it works for you or not. Time will tell. You'll always be able to trade it for about anything. Mesa's usually hold their value well compared to other brands.
Since attenuators are on your mind; I would not recommend the thd hotplate. I own one and can say that it's just not worth the price for what you're planning on doing with it. It's more for amps that power amp overdrive is the major part of the sound. And most attenuators are. If you're just trying to get a good signature mesa high gain tone at bedroom volumes, an attenuator isn't going to make a big difference. Tone for dollar, it's just not worth it in my opinion. There is no substitution for good old volume. You get the interaction and feedback with lots of volume, because the sound waves are talking to your guitar strings and you get this beautiful dance between your guitar and amp. Most modern high gain amps utilize a fairly clean power section and all the drive comes from the preamp. With the JP2C, the sweet spot seems to be right when the power tubes are working just hard enough to compress the signal a bit. If you turn it up louder, and overdrive the power tubes, you get a loose, over compressed and flubby tone.
Just my experience. But if you're set on it, find out for yourself. Only you know what you like. Report back if you get it, tell us how you like it. Good luck!
PRS 408
Les Paul Custom 08
Edwards Alexi
Mark V
JP2C
dotonfire
Post by dotonfire » Mon Jan 08, 2018 9:27 pm
Mine works out just fine at bedroom volumes. Sure, it's always better to crank it, and it's absolute overkill, but I'm pretty satisfied.
Mesa JP-2C / Mark III Purple / Recto 2x12 Vertical
EBMM JP15-7/ JP12 / JP7 | Blackmachine B6
Fractal AX8 / AXE-FX Ultra / MFC-101 Mk III
desertdweller
Post by desertdweller » Tue Jan 09, 2018 9:51 pm
From my experience, Mark series Mesas are great at low volumes. You have to tweak a recto a bit for a low volume sound, but Marks are a bit easier to dial in a low volume sound. Just turn the master volume down ! :)
T85
Post by T85 » Wed Jan 10, 2018 2:42 am
Thanks for the feedback, everyone. This will be my very first Mesa and by far the highest end piece of gear that I've ever owned. Aside from the little evh 15 watt lunch box that I just got about a year ago, I've only ever had solid state practice combos (line 6, peavey vypyr etc) And I've got to say, making the switch to that little 15 watt blew me away so I'm more than positive something like the JP-2C is going to flip my wig.
bandit2013
Triple Recto
Post by bandit2013 » Tue Jan 16, 2018 7:21 am
+1 with what others have said. At reduced volumes the bass seems to dominate. Shred mode corrects the frequency response quite well and sounds very similar to the amp running at elevated volume levels without shaking the house down. There is also the 60W power switch (manual suggests using the 4ohm tap with 8 ohm load to compensate). Other pedals that may work would be the grid slammer or Flux drive. I have both and tried it with the JP-2C. The grid slammer almost does the same trick as the shred mode. Also you can use that for a softer clip on the Clean channel if you need to have a different characteristic of distortion than you can get with the other two channels.
Maddnotez
Post by Maddnotez » Tue Jan 16, 2018 11:18 am
FWIW, I am a rookie. I literally JUST got this amp on Friday and have only had a few hours with it.
However, I am finding the opposite of what some are saying. I play modern metal, I like high gain, saturation, brutal tones and this JP2C brings the goods.
My issue is, I get the absolute perfect tone at bedroom volume. (my bedroom volume is 10:00 or so) But when I play with a drummer I have to turn up a bit and I lose that tone.
I am brand new to this amp and hopefully I can dial back the settings and keep my same tone at a louder volume but to me, this amp excels at lower volumes. Like small club, being miked up and gigging volume. The struggle for me is band practice with a drummer. I guess I prefer pre amp distortion with this amp.
Edit: This is with my 2x12. Have not been able to run to my 4x12 yet which may yield different results.
soundbee
Post by soundbee » Fri Jan 19, 2018 1:32 pm
I too use this at "bedroom" and live volumes. To my ear the performance of the speaker is what's really changing. The feel and gain levels feel about the same - but the "saturation" of the speaker seems much smoother at lower volumes. That said, it's probably just that Fletcher-Munson thing going on. Personally I'll just dial out a few frequencies that might be annoying me (or lacking) and then move on and just accept the fact that it's going to sound different "at volume" and in the room. Sometimes , stepping to the side or placing amps in another room (and mic'ing) can get back some of that lower volume "goodness" that seems to go away when playing loud. But there's still nothing like blasting a 100w through a couple of 4x12's ... drummer? what drummer?
Jesse Daly
Post by Jesse Daly » Fri Jan 19, 2018 10:16 pm
yeah if you get the perfect tone at bedroom levels then try bringing up mids to compensate when you play loud as the fletcher munson curve will dictate that the highs and lows get louder faster than the mids as you increase volume.
Maddnotez
Post by Maddnotez » Sat Jan 20, 2018 12:31 am
Will read up on this.
