Tri Avatar Chorus
brabrown
I'm looking at putting a Free The Tone Tri Avatar in my effects loops. The specs list the max input as 7dBm, I can not find the specs of the signal level in the effects loop of the jp2c. Anyone here know the signal level in the effects loop? Anyone try this pedal in the effects loop of a jp2c?
not sure what the signal level rating is on the JP-2C as it is not stated in dBv or dBu..... but it seems quite compliant with instrument level effects that I could not used with the Mark V. When in doubt, try to find a resource that has both the JP-2c and the effect pedal you are looking for to try out with the amp before you buy it. (easier if you live near a Mesa dealer, I am not so lucky).
The Mark V is one to question is it safe? So far that one is the only amp I know of that is at line level but that does not mean the V is the only one.
