JP2c bedroom volumes?
one trick for reduced volume level playing with the JP-2C, Turn on Shred mode. this cuts the bass and balances the treble and midrange. Sounds the same as if you had shred mode off and Channel volume set to noon or a bit less.
It is not 10W loud like the Mark V. I did not buy the JP-2C to play at bedroom level anyways. It is quite similar to the Mark III and Mark IV in some respects but there is more gradual taper on the volume controls when compared to the older amps.
