Used TA-30 Issues Reverb/FX-Loop Noise and Intermittent Wonk
Greg Gibbs
Post by Greg Gibbs » Sun Feb 25, 2018 8:58 am
Hey everyone,
I just picked up a used TA-30 head. Overall, it's an impressive amp, however it has a few issues.
1. The Reverb/FX-Loop is really noisy on both channels. It goes away if it's bypassed, but my setup is 4CM and I use the loop. Is this normal? Can it be modified or fixed to quiet it?
2. The amp occasionally just goes into a solid loud buzz. I linked a video in my dropbox. I'm trying to diagnose it without ordering a full tube replacement set.
https://www.dropbox.com/s/desvwazrvfc0n ... 8.m4v?dl=0
rotarysmp
Re: Used TA-30 Issues Reverb/FX-Loop Noise and Intermittent
Post by rotarysmp » Tue Mar 13, 2018 11:46 am
My TA-30 2x12 combi has very similar issues. I posted a similar video as you made here:
https://www.youtube.com/watch?v=UebU30a0WIo&t=1s
Did you contact Mesa Boogie support? I sent them a detailed e-mail nearly 4 weeks ago, as there is no M-B service partner in my country, but haven't received any response yet.
Mark
rotarysmp
Post by rotarysmp » Sat Mar 17, 2018 2:17 am
I resent my support request to Mesa, and they responded within a day ( their rep in Germany). They watched my youtube video, and sent me the three Tech bulletins which address these noise and switching issues. The mods are easy enough, so I'll do them once I get the cap, two resisters, and one J-fet required.
Great service from Mesa Engineering, so I suggest you email them a link to your video as well.
Mark
rotarysmp
Post by rotarysmp » Sat Mar 17, 2018 1:22 pm
I decided to to do the switching tech bulletin straight away, as it is only the addition of a 2.2kµF cap to the +15V supply. The tech bulletin from Mesa Engineering is very clear, although there is no a lot of room to work in this amp. Now the switching works properly. Thanks Mesa.
Mark
Greg Gibbs
Post by Greg Gibbs » Mon Mar 26, 2018 3:50 pm
Hey Mark,
Thanks for all of the info. I haven't emailed them yet. I switched out for a new set of tubes and one of the issues seems to be the seating of the tubes. I'll refer back to this as I get into it.
Hockeydog
Post by Hockeydog » Sat Mar 31, 2018 2:33 pm
I had a very good Mesa certified tech do the fixes. They certainly helped a lot but didn't completely eliminate the noise issue.
I plan on trying some 12at7's in V5 and V6 to see if that will help a bit more, although I don't expect a huge improvement. Good thing I like the amp otherwise.
