Using RA power section/multi-soak with external amp (MKIV)
rockhound76s
Santa Clara, CA
Hi folks. I have a RA100 and a Mark IV, both of which I love. As an experiment to get some different sounds going, I was hoping to run my Mark IV into the RA's power section, and take advantage of the RA's Multi-Soak feature.
In the RA100 manual, it says this about the loop:
The Loop Send is derived from a source at the end of the preamp and the RETURN is inserted back into the signal path near the input to the power section. The Loop is basically a patch point at the junction of preamp and power amp and this delivers the best signal to noise ratio and the least degradation of signal for most outboard devices.
So, if I run my MKIV's effects SEND into the RA's effects RETURN, then I'm using the MKIV preamp into the RA poweramp, which should then be able to attenuated using Multi-Soak. Is this correct?
I'm not risking/harming anything by doing this (as far as I can tell), but would appreciate confirmation. Thanks!
