Amonrae said:For the preamp, I had Mullard reissue, Tung Sol, JJ, Groove Tube, and Electro Harmonix on hand. After trying each, I thought they all sounded good but each changed the character of clean tone and distortion as well as onset of breakup enough that I couldn't determine all the differences in one session. I kept in the Tung Sol and like it better than the well used stock tubes. I wish I had fresh Mesa to compare with. When I have the time i'll try a further test after living with the Tung Sol a while.
scull said:Get you about 6 different 12AX7 tubes as well as a few lower gain tubes(ECC832, 5751) in different brands and swap out the tube in the V1 position. that is the position that makes the most difference tone wise. I love JJ's in every amp I own but that's me not you. Best thing is not to take anyone's advice but listen to your ear because no one else hears tone like yours truly.
Enter your email address to join:
