It is currently Tue May 22, 2018 8:54 am
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2, 3  Next
 Post subject: RA100 noisy reverb
PostPosted: Sun Sep 16, 2012 12:31 pm
The noise on the clean channel when the reverb is in engaged is really bugging me. Is this something that is common on all RA100s? I've swapped all the pre-amp tubes, power tubes, not the PI though. Can be heard when there is no input and master is off. Really annoying to have a high dollar amp (or any amp) not be dead silent. My MKV and Roadster don't give me this issue. Is this a design flaw or just my amp?
Roadster 2x12
Mark V
RA 100
Triaxis
(2)PortCity 2x12 OS
 Post subject: Re: RA100 noisy reverb
PostPosted: Sun Sep 16, 2012 8:44 pm
I don't have an issue with the reverb on my RA-100. You swapped power tubes for an issue that you narrowed down to being related to the spring reverb tank of the amp? Why would you do that?
If you swapped the tube for the reverb, the next thing I would to would be to check the connections of the wires that connect the tank to the amp. Pull them out and reseat them into their respective sockets. Turn on the amp and give it a go.
If you are having noise in your amp that is being further amplified by turning up your reverb, the problem isn't the reverb tank. Reverb tanks and reverb units in amps take the signal and any noise (good or bad) from the preamp and send it to the power tubes for amplification. If you hear a noise that gets louder with the reverb knob turned up, with nothing at all plugged in the amp, I would think the noise would be emanating from a faulty preamp tube. If the sound is happening in all channels, it is safe to say you have a bad PI tube (V-7). I had a noisy V-7 tube and swapped it out for a good tube and it solved my noise issues. Try one of Mesa's SPAX7s for that slot. They are quieter and ideally used for V-1 slots, but can make a world of difference in the PI due to their quiet nature.
Don't forget that if you swapped around tubes, you may have overlooked that the V-3 slot MUST HAVE A 12-AT7 tube and NOT the AX7 tube in it. That is the effect loop tube. With the Royal Atlantic, the effects loop is bypassed when there isn't an instrument cable hooked up. Therefore, your elusive noise issue probably isn't originating from the V-3 slot. Still though, I'd be sure that you have the right tube in V-3.
PostPosted: Sun Sep 16, 2012 9:43 pm
I hadn't narrowed it down to the reverb at that point. I had some extra tubes so while I had the back opened I swapped them.
I was aware of that and didn't swap that tube since I don't have a spare AT7.
Yep that is what I tried.
Thanks for the reply. Basically I'm trying to get a feel if it was something in general with the RA and the reverb. Somebody else had mentioned it as well. I'm glad to here you don't have an issue with yours that means I'll be able to sort mine out, thanks.
J.J wrote:
The reverb can be a bit noisey at low volume, but that is not an issue at higher volume.
Does the noise stop if you turn the master all the way down ? If not then it will likely be an issue with one of the power tubes or the driver tube and your shop should be able to do a change out for you under warranty.
Roadster 2x12
Mark V
RA 100
Triaxis
(2)PortCity 2x12 OS
PostPosted: Sun Sep 16, 2012 10:19 pm
I heard a bunch of people complaining that their TA-30 had noisy reverb circuits. Allegedly, Mesa told them that it was the nature of the beast due to the proximity of the reverb tank to the transformers.
Personally, I have no idea what to make of that whole can of worms. What I do know is that I've scoured the 'net for RA information since I've had it. I honestly haven't come across anyone else with a noisy reverb issue. Perhaps, and most commonly and likely, you are experiencing a tube issue. You may even have a few noisy preamp tubes causing issues. Good luck diagnosing your amp and getting it in correct playing form!
PostPosted: Thu Sep 27, 2012 12:20 am
You ever get this fixed? I had a similar issue with noise, and it was preamp tube related. Actually, it was only the first couple days I owned it. It was given a clean bill of health by a Mesa tech. He told me to let the brand new tubes 'burn in' a bit. The problem went away after a day of playing and has never returned. I've owned the amp since June, and just yesterday one of the power tubes died, making loud pops every few seconds. You could see lightning flashing in the tube too. Luckily, Mesa warranties tubes for 6 mos, so I'm getting a free pair (they're sold in matched pairs).
I love the amp. It sounds great, and is built like a tank. I will say that I believe Mesa's Achilles heel as of late is their tubes. Great amps, subpar tubes.
Mesa Royal Atlantic RA100
Past Boogies: 1984 Mark IIC+ short head, 1995 Dual Rec BlackFace, Stiletto Deuce II, Roadster
Recto 412 & 212 cabs
Various Stomps
Gibson & ESP guitars
PostPosted: Thu Nov 22, 2012 11:53 am
So I finally took the RA into a tech to look at it. He agreed that it was noisy. He then compared it to an RA sitting on the showroom floor and they were both equally noisy. So he concluded that there is nothing wrong with it because both amps were equally noisy :? An amp this expensive should be dead silent on the clean channel.
Roadster 2x12
Mark V
RA 100
Triaxis
(2)PortCity 2x12 OS
PostPosted: Fri Nov 23, 2012 1:15 am
Dude, I will make it a point to record my RA tomorrow to show you that that RA's clean channel isn't supposed to be noisy. I don't know what to make of the amp you tried on the showroom floor, but I tried two RAs out (of which, mine was ordered custom) and they both sounded fab.
I don't know how to explain what you heard, but I think you need to take your amp to a Mesa tech, or call Mesa and ask to speak to Mike B.
PostPosted: Fri Nov 23, 2012 10:41 am
I took the amp to a certified Mesa tech, he did the comparison not me. I will call Mesa, I should have done that already.
Here is a recording I just took of the noise. No instrument plugged in, all controls at lowest setting, on clean channel. Reverb is off initially. You can here it when I click it on. Then I engage the reverb and sweep its level. I don't like the constant background buzz that is there even when the reverb is off, then the reverb just piles on.
http://soundcloud.com/acplasma/ra-100-noise
Roadster 2x12
Mark V
RA 100
Triaxis
(2)PortCity 2x12 OS
PostPosted: Sat Nov 24, 2012 10:11 pm
Iceman --
Sorry, but I haven't had the opportunity to record anything for you yet. I did listen to the clip you posted though. First, I don't think it is necessarily a good thing to turn your amp up (volume wise) without an instrument connected. I could be wrong though about that point.
Your reverb situation is definitely strange though. I notice with the reverb maxed on my amp I get the slightest audible buzz, but it isn't really an issue since the reverb at that level is pretty unusable.
Let us know what Mesa recommends, as your experience may prove to be helpful to the other Royal users in the future. Meanwhile, I will see if I can get together some clips of my amp tomorrow (Sunday).
PostPosted: Sun Nov 25, 2012 7:42 pm
I had the master and gain at the lowest setting (i.e. no volume). All knobs where at their lowest settings. I turned up the mic preamp gain to make it obvious.
Roadster 2x12
Mark V
RA 100
Triaxis
(2)PortCity 2x12 OS
PostPosted: Mon Nov 26, 2012 6:15 am
I hope other RA users chime in here and back up what I'm saying about the cleans.
Sorry about your amp issues. Let us know what Mesa says when you call them. Having that type of hum is not normal.
PostPosted: Wed Mar 20, 2013 7:49 pm
I have the same issue with my Mark IV combo:
- When the reverb is on 0 without footswitch: dead silent.
- WHen the reverb is on 10 without footswitch: noisy
- When the reverb is on 10 with a footswitch switched off: noisy
So as soon as the Reverb knob is turned up it becomes noisy as hell... Wtf?
PostPosted: Sat Jul 13, 2013 12:07 pm
Hey y'all - new to the forum. Just picked up a Mesa RA-100 head recently and I'm loving it so far! I've also noticed the reverb circuit adds a little bit of noise - not enough to really annoy me but it's definitely there. The clean channel is dead quiet until I switch on the reverb. Overall, the RA is a pretty quiet amp and I'm extremely happy with the tone on all 3 channel modes - this is coming from a previous Marshall JVM owner (which I'm selling because of how amazing the RA is by the way :wink: ) and I've spent years modding and tweaking that thing to try to tame the noise/hum and it's still no where near stock RA. Mesa really knocked it out of the park with this amp!
PostPosted: Mon Oct 07, 2013 9:28 pm
Unplug the fan and see if that still is an issue. My Mark IV combo is relatively quiet, does not matter what the reverb is set to.
PostPosted: Mon Oct 07, 2013 9:45 pm
I am willing to bet that your power supply may have some ripple on it. You may have a leaky cap that is not filtering properly. The noise I heard definitely is power supply. However, it could also be a leaky tube, Heater noise bleeding into the cathode. You could always tap the tubes to find the noisy one. You could also pull tubes and check the sockets for metal fragments. I had found some shavings on one of my tubes that contributed to 60hz hum.
I do not have an RA100 yet but if the loop is similar to the early mark series amps, try the following: Does the noise go away with a bypass cable connected into the effects loop? (send to return). you could also try two cables into the effects loop with nothing connected. Should break the circuit path between preamp stages and final drive circuit. The mark III was similar with the jack/switch. Just plugging into the return would break the circuit. if the noise goes away you can rule out PI tube and power Tube circuits. This amp is simple in design since all the tubes are cascaded depending on which channel or mode you are in. It is just a suggestion, may not do anything at all.
