It is currently Sun Jun 24, 2018 1:58 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: RA100 noisy reverb
PostPosted: Tue Nov 03, 2015 11:57 pm
Ah, you're right. I see what you mean about the distance being too tight for the faceplate. Hey, you saved me like $75, so thanks.
PostPosted: Wed Nov 04, 2015 7:12 am
Your welcome.
I measured the width of the RA100 shell, inside edge is 25 1/4 inches. Definitely much wider than the amp chassis which is around 22 1/4 inches. I could probably fit the Roadster chassis inside the RA100 shell with the exception of the faceplate will get in the way. Also the depth is different too between the two chassis. I believe the RA100 chassis does not have a common ancestor like some of the other Mesa amps.
