Practice Amp
Assumer
Arkansas
Hey all you Atlantic Series guys. What would be a great home low volume practice amp. Looking for something I can take with me on trips and goof off with.
I actually like to use a modeler with headphone for quiet home practice or to take on the road. I use a Digitech GNX4 which has a ton of features and sounds pretty good with headphones. I also use an Epi Valve Jr. For home practice. This is a simple 5 watt amp that gets a pretty good vintage tone, although you may need pedals for heavier music. But even at 5 watts its pretty loud, so i usually go with the modeler if someone is around to complain.
The Blackstar HT-1 is worth looking at if you are insterested in a neat little tube amp. Just 1 watt, light and not to loud.
I just took a chance on a Rocktron Prophesy. I got it dirt cheap and thought I would get a used Power Engine 60 and try that as a low volume practice amp.
