RA 100 - Question Re Control Layout
Sukodil
I have the 2x12 combo. When facing the amp, the HI/LO Channel is on the left and the clean channel is on the right. I have noticed on some of the Youtube videos that some of the amps controls are reversed with the HI/LO on the right and the clean on the left. What's the deal? Was there a change in the control layout?
I'd assume that what you are seeing is the head version vs Combo. The combo is mounted flipped compared to the head version so the controls are on oposite sides. The front panel is also printed for the orientation so you can't swap a combo chassis into a head shell without the pot ratation and writing being upside down.
I didn't realize there was a difference between head v. Combo. Thanks for clearing that up.
