RA is in but....
Assumer
Arkansas
Just received it today. Sounds great but the reverb does not work. On the clean channel the more you turn the reverb knob, the brighter the channel gets but no verb. Any ideas? A tube maybe?
There is a kill switch for the reverb. If this is on, then maybe a bad tube in the reverb driver. If you have a spare tube, you might try switching it out. But I would check with the Mesa people first because you don;t want to void your warranty. Is the verb working on the gain channels?
It is fixed. Ended up being a loose wire I soldered back on. Good as new.
JOEY B. said:
Great news, where was the loose wire located?
It was inside the reverb tank. There are two wires at each end of the tank. Looking from the back of the head, it was the black wire on the left. Simple and quick fix.
The more I play this amp, the more I love it. The power soak is wonderful. If you have not played on, do so ASAP.
