Impedance Mismatch
DavidE
Impedance Mismatch
Post by DavidE » Thu Jan 13, 2011 8:20 pm
I know the amp can tolerate certain mismatches, but I have two 8 ohm cabs and no parallel box. Can I safely plug one into the 8 ohm output and the other into the 4 ohm output?
I play acoustic guitar in www.mothertruckerrocks.com
I play electric guitar in: http://www.facebook.com/pages/Whiskey-P ... 4215494761
I play bass in: www.jackedupband.com
Sebber
Re: Impedance Mismatch
Post by Sebber » Fri Jan 14, 2011 12:07 pm
Get a second opinion but in theory I think that's ok: I'm no expert but my understanding is that as long as the ohms load on the speaker isn't less than the output on the amp you don’t damage the output stage of the amp. 4 ohm output into an 8 ohm speaker is fine as far as I understand it.
However, someone way cleverer than me needs to clarify whether or not it’s safe to use both the amp’s speaker outputs at the same time.
So many drummers, so little time.
DavidE
Post by DavidE » Fri Jan 14, 2011 12:14 pm
Well, I tried it anyway and actually preferred the sound of the Thiele only so that's what I'm going to go with. ;-) I still may need the answer for other speaker cabs.
BoogieJem
Post by BoogieJem » Sun Jan 16, 2011 2:37 pm
Sebber wrote:Get a second opinion but in theory I think that's ok: I'm no expert but my understanding is that as long as the ohms load on the speaker isn't less than the output on the amp you don’t damage the output stage of the amp. 4 ohm output into an 8 ohm speaker is fine as far as I understand it.
Its been a while since I learned this stuff but I thnk if the amp is perfectly matched with a single 4 or 8 ohm speaker in the appropriate output then using both at the same time will result in a mismatch (reflect back a combined lower load to the primary winding of the OP transformer) and cause more power to be dissipated in the output tubes - potentially reducing the life of the tubes.
Mesa Mk IV, Mesa LSC 2x12, Mesa TA-15 Mesa Thiele 1x12 C90, Peavy Classic 30, PRS Swamp Ash Special, PRS Custom 24, Gibson ES-135, Fender Baja Tele
Sacausey
Post by Sacausey » Mon Jan 31, 2011 1:23 pm
can't you just chain the cabs together and run them out of the 4 ohm output? (most cabs, in my experience, allow you to do this)
(1/R equivalent) = (1/R1) + (1/R2)
So you would have 1/8 + 1/8, which is 2/8, which is the same as 1/4. So your total resistance would end up being 4 ohms.
http://www.1728.com/resistrs.htm
Guitar: Fender Strat. AT1 in the bridge and Cruisers in the neck and middle.
Pedals: BB Preamp, Maxon OD808, Strymon El Capistan, Strymon Bluesky
Amp: TA-15, Sourmash 112 with a Green Barret.
DavidE
Post by DavidE » Mon Jan 31, 2011 2:06 pm
Sacausey wrote:can't you just chain the cabs together and run them out of the 4 ohm output? (most cabs, in my experience, allow you to do this)
That works if one of the cabs has two jacks. In this case, both have only one. But it turns out I liked the sound of the Thiele by itself better than both together so the issue became moot.
guitarguy56
Post by guitarguy56 » Sat Mar 05, 2011 5:55 pm
Help !!! Im ashamed that I do not know this stuff, but it is what it is, and I dont want to hurt my new equipment.
My MB TA15 has a 4 ohm and a 9 ohm out jack. My new REC series MB 2 x 12 Cab (that was a floor model and did not come with a manual)
has two input jacks......one for 4 and one for 8. From reading on here, I understand I can do the 8 ohm out on the amp to the
4 ohm in on the cab and it will sound different, but no harm will come to my equipment. So I guess its also ok to do a 4 out on the amp into
the 4 in on the amp, but never a 4 out on amp into the 8 in on cab.
WHat are the differences I will experience in sound when I do any of the above and what is safe and the recommended ?? I have only done the 8 out and 8 in so far.
Thank you for your help and info!!!
BoogieJem
Post by BoogieJem » Mon May 02, 2011 5:18 am
Sorry I've been away from this board for a while so did not see this - but you have it the wrong way around. It is safe to plug a higher Ohms speaker input into a lower Ohms output on the amp (eg 8 Ohm speaker into 4 Ohm output) the result will be a little less volume and sometimes a warmer tone. A perfect match is naturally 8 Ohm to 8 Ohm or 4 Ohm to 4 Ohm this is how the amp was designed to operate and gives the loudest output. A potentially harmful mismatch is to have the amp drive a lower Ohm speaker than the rated output this causes the tubes to dissipate more power as internal heat.
Hope that helps
hbach
Post by hbach » Mon May 02, 2011 10:37 pm
For anyone with doubts on this topic I put an Excel sheet on another forum that will help you calculate the total impedace, even using the different outputs of the amp.
http://www.marshallforum.com/attachment ... hookup.zip
Always check what you are doing and read the manual :) The sheet is just a calculation tool and does not replace checking the connection and feasibility.
hbach
Post by hbach » Tue May 03, 2011 5:48 pm
By the way: One 8 Ohm cab into each output is not OK. It's like plugging in an 5,33 Ohm cab into the 8 Ohm output.
Good you didn't like it.
