Electra Dyne Volume Taper
jnoel64
Post by jnoel64 » Tue Mar 05, 2019 11:29 am
I read a little bit about the DC series having the same issue as the Electra Dyne: master volume goes from too quiet to too loud way too quickly. I read there is a resistor attached to the master output in that series that can be clipped and it supposedly smooths out the taper. I can't find a schematic for the Dyne (and probably couldn't understand it if I did), but I am curious if the Dyne also has that same setup. Anyone ever take a look?
__________________
Mostly Fenders with Duncans
Eevil
Re: Electra Dyne Volume Taper
Post by Eevil » Tue Mar 05, 2019 2:51 pm
Hi.
I solved the volume taper issue with extra volume pot in fx loop (simple volume pedal works also.. but I diy’d from parts found at home). No mods needed in amp itself which is nice.
Other mod would be to mod the reverb circuit to return the wet signal before fx-loop so that it would not be parallel to fx loop.. but no idea what would be the total effect to sound/feel... currently the reverb doesn’t work if the volume is under 8 o’clock
Current:
- Diezel D-Moll
- Electra-Dyne 1x12 23” combo
- Studio preamp
- 2x12 Recto horizontal
- 4x12 Stiletto slanted
Gone:
- Mark III 60w/grx
- Express 5:25
- Roadster head
- Triaxis / 2:50
- Stiletto Deuce Stage 1&2
- CAA OD-50
- Mark V
jnoel64
Post by jnoel64 » Wed Mar 06, 2019 10:43 am
I've used one of those volume boxes in the loop of another amp and it seemed to work ok. That was before I actually used the effects loop, lol! I suppose I could put one of those at the end of my effects chain right before the return. I'll have to try that.
__________________
YellowJacket
Post by YellowJacket » Tue Mar 26, 2019 12:16 am
The volume taper on these things is ludicrous. I have a 1 x 12, which is useable, but I found a torpedo live is the best solution to tame the beast!!
