New ElectraDyne released by Mesa
bigbaron
Post by bigbaron » Tue Nov 29, 2016 3:07 am
Well its pretty close. Its clean and low gain ch sound very familiar. 3 Sep channels, individual controls, Solo, Midi, Sep Reverb, Cabclone. Sep Bias. Only thing its missing is switchable power.
Mesa Triple Crown TC-50
https://www.youtube.com/watch?v=xLEZzQK ... e=youtu.be
J.J
Re: New ElectraDyne released by Mesa
Post by J.J » Wed Nov 30, 2016 6:11 am
Awsome. Looks more like an RA2 to me than an ED2 though. I'll definitely be checking one out and would love to upgrade my Express 5:25 combo. The new TC seems to have all I want, crunch and clean on separate channels, solo boost 50 watts and great rock through to modern tones.
I still have my ED, but as I always found the bass difficult to control in the gain modes it rarely gets used. The TC looks like it will be pretty tight in the bass and also adds the tight mode for the gain channels too.
The RA has been my man amp for many years now and has been fantastic. The only things that I sometimes wished it had were separate tone controls for the vintage gain channels and a presence control to help tame the top.
A 1x12 combo that hopefully isn't to heavy that I can use for rehearsal and gigs would be great.
Triple Crown 50 combo
Express 5:25 1x12 combo
JCM800 2203
Deluxe reverb reissue
jnoel64
Post by jnoel64 » Fri Dec 02, 2016 11:45 am
The Dyne, to me, is much darker than the TC-50. Nothing at all like the Dyne in the demo to my ears. But, it does look like a very interesting amp!
__________________
Mostly Fenders with Duncans
elvis
Post by elvis » Fri Dec 02, 2016 1:42 pm
I think you could look at the TC50 as a new Royal Atlantic or as a new Express 50. I really don't see it as an Electradyne.
I do think that the 6V6 option is really cool. I had asked for a lunchbox Dyne/RA with 6V6 a while back. This isn't a lunchbox, but it is intriguing.
Mini Rectifier blue LED
Stiletto ACE
F50 Combo
Recto 2x12 Vertical
Recto 2x12 Wedge
jnoel64
Post by jnoel64 » Mon Dec 05, 2016 2:23 pm
The 6V6 tube option is exactly why I'll be pulling the trigger on one of these. Then I will have that awful decision to make about which amp to take to a gig. Unfortunately for my Dyne, the TC-50 may win more times than the Dyne just because of the weight on the TC-50. Unless I can get a roadie that is willing to work for free....
__________________
Hollis
Post by Hollis » Fri Dec 16, 2016 11:11 am
JJ, when I first got my Electra Dyne I too struggled with the amp having too much bass. However I have since found settings that work. If your middle control is set below 12:00 then a lot of the upper mids get cut, and allowing more bass to pass through. Also, setting the treble control above 12:00 will reduce bass as well. The higher the gain, the more the bass can bloat.
My settings:
Volume (gain) 2:00
Bass 8:30 - 9:00
Middle 1:30
Treble 1:30
Master - Low enough to play in an apartment most of the time
These settings work very well with no bloated bass.
Electra Dyne 1x12 combo with the C90
Deluxe Reverb Reissue
American Deluxe strat
PRS Custom 22
J.J
Post by J.J » Fri Jan 13, 2017 3:33 am
Hollis wrote:JJ, when I first got my Electra Dyne I too struggled with the amp having too much bass. However I have since found settings that work. If your middle control is set below 12:00 then a lot of the upper mids get cut, and allowing more bass to pass through. Also, setting the treble control above 12:00 will reduce bass as well. The higher the gain, the more the bass can bloat.
My settings:
Volume (gain) 2:00
Bass 8:30 - 9:00
Middle 1:30
Treble 1:30
Thanks for that, good advice.
My settings are pretty similar to yours, but I probably have the mids lower. I'll try it with extra mid. I seem to remember wth the bass set low something gets lost in the mids as well.
Is yours the wide or compact combo?
JCM800 2203
Hollis
Post by Hollis » Sat Feb 11, 2017 1:55 pm
Mine is the widebody, 27" combo with the stock Mesa C90 speaker. I also have a Recto 2x12 cab with English made Marshall V30's and it has a bit more forward upper mids. I honestly prefer the stock C90.
PRS Custom 22
mccart125
Post by mccart125 » Tue Feb 21, 2017 6:36 pm
Hollis wrote:Mine is the widebody, 27" combo with the stock Mesa C90 speaker. I also have a Recto 2x12 cab with English made Marshall V30's and it has a bit more forward upper mids. I honestly prefer the stock C90.
I agree. The ED sounds better with a C90. I also have a Boger 2x12 loaded with a greenback and a creamback.. Sounds pretty good with that too. The ED sounds good with single coils as well.
Mesa Electra Dyne
Mesa Recto-Verb 25
EVH 5150 III
Bogner GoldFinger
Mesa 2x12 Rec Cab
Mesa 1x12 Open Back
Bogner GoldFinger 2x12 Cab
Mesa Cab Clone
PRS P245
Chapman ML-3
Epiphone Les Paul Custom
Fender Strat Custom Shop
Charvel Custom
