Problem W/ New To Me Electra Dyne
cmmallinson
Post by cmmallinson » Thu Jul 14, 2016 6:42 pm
Gentlemen,
It has literally been years since I've been on TBB and since I've owned a Mesa amp. Glad to be back. I just acquired a 2009 Electra Dyne 1x12 Widebody. It is by far my favorite amp to date. I have one issue with regards to which I require your advice and wisdom. When I engage the reverb, it adds a ton of gain on the HI/LO and a pretty healthy amount on the clean. I do happen to know that the gentleman I acquired it from had just had it retubed with a JJs tube set. Is it possible that the tube that drives the reverb is a high output tube? If so which tube should I replace it with? Or what else could be the issue?
(Current) Mesa Electra Dyne 1x12 (Past) Fender HRD III, Hughes/Kettner TM 18, 1972 Fender PR, & Mesa Roadster & 2x12 Recto Cab / (Current) '90 PRS Signature CU24 10 Top, Epiphone Les Paul, Taylor GA7, & Vester Strat (Past) PRS CU22
elvis
Re: Problem W/ New To Me Electra Dyne
Post by elvis » Fri Jul 15, 2016 11:44 am
The Dyne is designed to have all 12AX7, including the loop and reverb drivers.
One quirk of that amp is that the reverb bypasses the loop. So if you have an FX unit in the loop and use that to control master volume by dropping the FX output signal, the reverb will come out super loud by comparison.
Mini Rectifier blue LED
Recto 2x12 Vertical
Recto 2x12 Wedge
screamingdaisy
Post by screamingdaisy » Fri Jul 15, 2016 8:06 pm
How low are you running the volume?
I find the ED doesn't start to "work right" until it has a bit of volume behind it. At extremely low volumes the reverb tends to add a harsh brightness that goes away as the amp's volume increases.
cmmallinson
Post by cmmallinson » Fri Jul 15, 2016 9:12 pm
So, I haven't run any effects in the loop as of yet. However, I am running the MV about as low as it can be and still sound decent. I live in an apartment that necessitates that practice. I imagine that is the issue. I suppose I should start shopping for an attenuator. Thanks for the help!
Eevil
Post by Eevil » Mon Jul 18, 2016 3:40 pm
cmmallinson wrote:So, I haven't run any effects in the loop as of yet. However, I am running the MV about as low as it can be and still sound decent. I live in an apartment that necessitates that practice. I imagine that is the issue. I suppose I should start shopping for an attenuator. Thanks for the help!
I had the same issue with master volume and tinkered passive volume box as an solution. Just one 250k log pot in fx loop and the issue is a bit more manageable :) it is not perfect or anything but better than the jumpy MV which would travel from dead to earthquake with one small nudge (at least it felt that way when children are sleeping ;)) The reverb is not working properly as it is post fx loop...
Just a cheap alternative to attenuator..
Current:
- Diezel D-Moll
- Electra-Dyne 1x12 23” combo
- Studio preamp
- 2x12 Recto horizontal
- 4x12 Stiletto slanted
Gone:
- Mark III 60w/grx
- Express 5:25
- Roadster head
- Triaxis / 2:50
- Stiletto Deuce Stage 1&2
- CAA OD-50
- Mark V
danyeo1
Post by danyeo1 » Mon Jul 25, 2016 11:12 pm
You're better off using a Reverb pedal in the FX loop...IMHO.
MarkIIC+,III, IV and V, ED clips here.
http://soundcloud.com/danieldowning
