volume pot change
kramerxxx
volume pot change
Post by kramerxxx » Sun Dec 21, 2014 12:00 pm
Would putting in a different volume pot give the Clean channel a little more gain? Say going to a 500k or 1M pot. I did this in my Dual Rec and it allowed it to get better lead tones, without the od pedal.
I typically run it maxed and then push the front with an od pedal.
elvis
Re: volume pot change
Post by elvis » Mon Dec 22, 2014 4:18 pm
The pots are ganged to allow different characteristics for each mode. Not easy to replace. You would need a custom pot.
Mini Rectifier blue LED
Stiletto ACE
Recto 2x12 Vertical
Recto 2x12 Wedge
