ok I guess I need a retube
satch5150
hi guys could you suggest some nice tubes for my Dyne? Mesa tubes are really expensive here (Poland) and for half the price I can get EXH, JJ electronic, Svetlana, Tung sol, Sovtek. I'm looking for low noise/ good reliability and kinda the same amount of gain. Could you suggest sth, I'm kinda new to tube amps
what did you choose in the end?
I prefer JJ and sovtek LPS's. Anyway I found tubes on ebay at around 180 USD direct for the Dyne but haven't bought yet.
I believe Mesa uses JJ, though they select them for certain criteria. Preamp tubes are reasonably inexpensive, so you should get a couple different kinds and try them out.
Many people like SED winged C for power tubes.
Found this out there......
STR-417 6V6 - TAD 6V6GT
STR-425 5881 - Sovtek 5881WXT
STR-440 6L6 - TAD 6L6GC-STR
STR-447 EL34 - Electro-Harmonix EL34
STR-450 - NOS Siemens EL34
EL84 - Electro-Harmonix EL84EH
12AX7 - Chinese
SPAX7A - Sovtek
12AT7 - Chinese
5AR4 - Shuguang 5AR4
5UG4 - Sovtek (black base) or China (brown base)
5UG4B - Electro-Harmonix 5U4GB
5Y3 - Sovtek
wekiitoedzo said:
Somebody could help how to remove the tube grill from behind for a 1x10 combo?
Do i have to remove the whole back panel?
With my combo I need to remove the back panel to get access to the grill that protects the tubes. The port just isn't wide enough for me to adequately fit my hands and fingers to where they need to go in order to reach the clips that unlock the cage.
