running external cab
Yes.
If you are running the combo speaker and the external cab at the same time, make sure you have the switch in the 4 ohm position.
If just one, make sure it is in the 8 ohm position
primal said:
Yes.
Thanks for the info......the setup below sounds fantastic!
