Hello Friends,
New to the board!
Just stumbled on this page and thought I'd add my 2 cents.
I'm in a Metallica tribute from the mid-west called "Damage Inc." (Yes, there are several throughout the country with this name :roll: )
This is how I understand James clean tone is captured.
I use a similar setup and it sounds great! Very bright and chime like!
James:
As most of you know James blends his tones:
Crunch = Triaxis #2, Lead 2 Yellow with a "Phase Inverted IIc+" Mod. and a custom Mesa graphic EQ in the loop (Slaved from a Mesa studio Pre-amp)
along with a Diezel VH4 on channel 3 or 4 depending on the song.
and for the Clean:
Roland JC-120H with a Electro Harmonix Bass Micro Synth and an MXR Phase 100 in it's loop. (MXR is used for songs like "Bleeding Me", Could be in the chain with Triaxis?)
along with his Triaxis #1, Rhythm Green with TC G-Major and a Boss CH-1 in the chain.
I think that Warble sound he gets in the clean tone is produced from the EH Bass Micro Synth. This maybe the secret weapon, if you will? This is on my list of pieces of gear to add to my rig. If anyone tries this, please let me know how it goes. I've dug up a picture of his settings on this unit.
This setup may or may not be 100% fact. In my many hours of Metallica tone research, this is what I've put together from the information I've gathered.
As I stated earlier, I have a similar setup.
I'll share my clean settings...
This is based off using a Gibson Les Paul Studio with EMG Pickups
81 in Neck and 85 in Bridge. This is the case in most of my guitars. Some have 60 in the Bridge. The 60 has a little more Bass response than the 85.
(Left Side)
Mesa/Boogie Mark V (with Marshall 1960A Cab)
Channel 1
Fat mode
EQ Off
90 Watts
Bold
Gain 9 o' clock
Master 9 (or to preference)
Presence 11:30
Treble 1:30
Mid 9
Bass 1
Reverb 11
Loop Active at 3 o' clock
In the Loop of the Mark V I have a Line 6 Pod X3 Live
Settings:
Dual Tone
Tone 1:
Amp: 1987 Jazz Clean (JC-120 Model)
Bypass Vol 79%, Room 34%
Cab: 2X12 87 Jazz Clean, 67 Condenser Mic
Bass 49%, Mid 63%, Treb 71%, Pres 68%, Drive 31%, Vol 95%
Mod: Sine Chorus
Speed 0.87HZ, Tap off, Tempo 120.0bpm, Mix 50%, Depth 56%,
Bass 39%, Treb 58%, Post Config
Reverb: Brite Room
Predly 50%, Decay 37%, Tone 50%, Mix 44%, Pre Config
Noise Gate = Thresh -70db, Decay 38%
Compressor: Thresh -32db, Gain 0db
Tone 2:
Bass 49%, Mid 62%, Treb 71%, Pres 68%, Drive 31%, Vol 95%
Mod: Stereo Square Chorus
Speed 0.70HZ, Tap off, Tempo 120.0bpm, Mix 54%, Depth 34%,
Predly 28%, Fdbk 25%, Post Config
Reverb: Brite Room
X3 Output Settings:
Stack PWRAMP, Tone 1 and 2, On, Pan 12 o' clock
Master Volume (knob on unit): 10:30
(Right Side)
Mesa/Boogie Simul-Class 2:90 Power-Amp, Presence Knob at 11:30
with a Marshall 1960B Cab.
Mesa/Boogie TriAxis on Rhy Green
4.0, 6.0, 2.0, 2.0, 0.0, 0.0. 5.5, 6.0, 3.0 (Nothing in Loop) Output: Max
Along with a TC G-Major and Modded Boss CH-1 in the Chain.
What I mean by in the chain?
I'm using a Voodoo Lab GCX w/ a Ground Control Pro.
First I'll mention my 8 Loops on the GCX.
1. Ibanez Tube Screamer
2. Boss CH-1
3. Mesa TriAxis
4. ADA MP-1
5. Marshall JMP-1
6. TC G-Major Left
7. TC G-Major Right
8. Mesa Mark V
(I'll create a Post of my rig setup if anyone is interested. I'm quite sure this is a vague description of it as a hole.)
So The Chains goes:
Boss CH-1 -----> TriAxis ----> TC G-Major Left-----> BBE Sonic Maximizer Stomp----> Mesa 2:90 Channel A.
So CH-1 before the Triaxis and G-Major after the Triaxis.
TC G-Major Settings:
Preset 1 named CLEAN
Mix Fil 100%
Pit 25%
CHO 0%
DLY 15%
REV 25%
CHO/FLA:
Subtype Class.Cho
CHO Speed 2.05 HZ
CHO Depth 68%
CHO Tempo Ignored
CHO High-cut 7.08 KHZ
CHO Mix 0%
CHO OutLev 0%
Reverb:
Subtype Hall
REV Decay 2.5 s
REV Predly 100 ms
REV Shape Curved
REV Size Huge
REV Hico1 Clear
REV Hifact 0
REV LowCol Tight
REV Lowfact 9
REV Roomlvl 0
REV Revlev -6db
REV Deffus 0
REV Mix 24%
REV Outlev 0db
Boss CH-1 Super Chorus Settings:
(This Pedal is Modded, I'd have to dig up the diagram on the Mod for specifics)
E.Level MAX
EQ 2 o' clock
Rate 9 o' clock
Depth Max
These Setting get me very close to James Clean Tone for any era of his tone.
