James' ADA mq1
You to can now master the Metallica sound like a puppet.
Darth Bacelar
James' ADA mq1
Post by Darth Bacelar » Mon Feb 08, 2010 2:28 pm
Anyone knows why or how he used this eq? I have one, and I can get very nice sounds with it. But it would very interesting thing if someone knows anything about the relationship of James and the ADA. :wink:
I supose he used it with the IIC+ head... http://forum.grailtone.com/viewtopic.ph ... 26&start=0
ryjan
Re: James' ADA mq1
Post by ryjan » Mon Feb 08, 2010 3:00 pm
We need more info on how you're using it. What amp are you using, settings, guitar, pick ups, etc.
Mark V:25
Recto 2x12
ESP Explorer
Darth Bacelar
Re: James' ADA mq1
Post by Darth Bacelar » Mon Feb 08, 2010 4:14 pm
I´m using it in the loop of my quad preamp. All my guitars actually have EMG 81. And for now, I only use the mq1 in channel 1, but I would like to know how hetfield use the mq1 in the IIc+
And the settings are very similar that the Fleming's notes in the and justice recording
ryjan
Re: James' ADA mq1
Post by ryjan » Mon Feb 08, 2010 5:30 pm
You have the right gear for the Jaymz sound. :twisted: In the notes I have seen (and I'm going off memory here) James cuts some mids around 1.2k and bosted the lows at 120 and the highs at 4.6k. Start at these frequencies and adjust the level and Q till it sounds right.
Mark V:25
Recto 2x12
ESP Explorer
Darth Bacelar
Re: James' ADA mq1
Post by Darth Bacelar » Tue Feb 09, 2010 8:22 am
Yeah, It makes sense. I have the notes, but i don´t understand very well the B&B eq :lol:
And some idea about the sound of black´s album tour? since 91 to 93 he used the mq1 live and gets very close to the album´s sound. I only have one pic about the IIc+ settings (in the link I posted before) but I don´t very satisfied with the sound that I get.
Any idea, or suggestion? :P
Elpelotero
Road King
Re: James' ADA mq1
Post by Elpelotero » Tue Feb 09, 2010 8:43 am
In that picture the treble is turned WAY low. I think he was using the boogie for low end and had something else in the rack/studio to give the high end, but we don't know what nor have it. So, I would suggest using the Master/Justice settings for the tone controls and then putting the graphic EQ in the M shape that he used for black album. This is how I get close to black album sounds at home.
'92 Dual Recto Rev. D, Volume mod
'84 Mark IIC+ Coliseum
'85 Mark IIC++ DRG, V1 mod
Mesa Standard 4x12
1980's EV Thiele
Sold:
'92 Dual Recto Rev. C
'92 Dual Recto Rev. E
'05 Dual Recto 3ch
'84 Mark IIC+ DR
http://www.TheBoogieArchives.com
Darth Bacelar
Re: James' ADA mq1
Post by Darth Bacelar » Wed Feb 10, 2010 5:33 pm
I tried to use the justice settings with the M eq, but, i don´t really sure about the sound I get.
Anyway, I tried again with the treble very low, and getting it with the ADA, + M graphic, and I believe that sounds better, but I need more experiment : D
The M eq should be like that? I mean, I tried with the 240 and 2200 pots over the first line, I think it sounds very different when there are over or behind the first line.
All suggestions are welcoming! :D :D
ryjan
Re: James' ADA mq1
Post by ryjan » Wed Feb 10, 2010 6:21 pm
Try to get the best tone you can with the GEQ before adding the parametric.
Mark V:25
Recto 2x12
ESP Explorer
Darth Bacelar
Re: James' ADA mq1
Post by Darth Bacelar » Fri Feb 12, 2010 10:19 am
Actually, the ADA mq1 it´s a graphic eq, not a parametric. But anyway, I can get very nice sounds with it. I´m still using it since I had a dual recto head.
Re: James' ADA mq1
Post by #2121313 » Fri Feb 12, 2010 6:54 pm
Darth Bacelar wrote:Yeah, It makes sense. I have the notes, but i don´t understand very well the B&B eq :lol:
Here ya go:
TheCapstan
Re: James' ADA mq1
Post by TheCapstan » Sat Feb 13, 2010 1:29 am
Guys,
you are over thinking the whole thing... U dont need the exact equipment with the exact settings you think James used to get the right 'Metallica sound'.
No one, including James or Kirk will be able to get the exact same sound as in the 'black album' or justice or any other album, because there are many other factors involved, most of them are eq's and processors that where added in the studio after the tracks where recorded.
The signature Metallica sound until Justice was MK C+ with Marshalls
Since Justice the sound was created using: ADA mp1 ---> Dual rectifiers, combined with MK C+ and Diezel at different levels
Since Load the ADA MP1 was replaced by Triaxis.
As long as you use the same amps, at decent volume levels (at least 40% output, to let the tubes open up) you will get a 'Metallica sound'.
Im a sound engeneer and have played with James and Kirk several times. They also use Orange and silverstar amps....
Just have fun playing!
TheCapstan!!!
Darth Bacelar
Re: James' ADA mq1
Post by Darth Bacelar » Sat Feb 13, 2010 9:48 am
Mmmmm so... I believe that if you use the white pot its reduce that frequency and if you use the orange pot, you boosted it, right?
And well, I know it´s very hard, maybe impossible to have the exact tone the had, becouse there´s magic in the studio, and engineering, too. But you can get close, or more close, if your equipment are similar to the one day they had.
Even so, I don´t have the exact equipment, but I get a very pretty and justice tone with the quad and the mq1 : D
Re: James' ADA mq1
Post by #2121313 » Sat Feb 13, 2010 8:49 pm
The orange pot (smaller) controls the db (boost OR cut) and the white (larger) pot controls the frequency.
The orange button beside controls whether you are boosting or cutting the frequency.
Darth Bacelar
Re: James' ADA mq1
Post by Darth Bacelar » Wed Feb 24, 2010 5:20 pm
But i don´t understand something. I´ll be pleased if someone can explain me this:
http://web.me.com/fwrproduktion/FWR_Pro ... s_2.html#6
Ok... I think the column of the right on paper, is the first, starting to count by the right, and the another the second of the right. Its coincide the freqs with the notes.
The black point means that freq is boosted, and the white point is cutting, right? But in the last two pots, on the bottom of page, you can see a dark and a white points.
What´s mean that? They boosted or cut the freq? :roll:
Re: James' ADA mq1
Post by #2121313 » Wed Feb 24, 2010 7:06 pm
Sorry if I don't answer your question bang on, but here's a good read that covers some of what you may be looking for, a few posts down you see Flemming explain the notes and what they mean.
http://www.gearslutz.com/board/so-much- ... n-metallic
a.html
