http://forum.grailtone.com/
Mesa Boogie Quad settings for Puppets/Justice crunch
http://forum.grailtone.com/viewtopic.php?f=35&t=36377
Page 1 of 2
Author:  Friedmett [ Fri May 29, 2009 9:26 am ]
Post subject:  Mesa Boogie Quad settings for Puppets/Justice crunch
Here is my basic settings for Lead 2 on my Mesa/Boogie Quad preamp. I based them on the actual Metallica recording settings of Puppets and Justice which I found at a sweetsilence page which is now gone. So What issues (Metallica club mag) from 2008 has Kirk's early days in details and some of the pictures of the same Puppets recording notes are alo present.
EQ is mostly done by my ear. Justice is less mids and EMG's ad to the tone so it's pretty close but fine tunning maybe needed.
I plug straight into the Quad with my Jackson RR2772 with seymore duncans sh6 and sh4.
These settings will work with Mark IV and I guess any other Mark series as well.
Author:  Elpelotero [ Mon Jun 22, 2009 10:05 pm ]
Post subject:  Re: Mesa Boogie Quad settings for Puppets/Justice crunch
So the So What mag had pictures of Flemming's notes? That's pretty cool.
Author:  #2121313 [ Sat Jul 25, 2009 2:33 pm ]
I tried this EQ curve on my Mark V in C+ and it works good, sounds nice and tight. The added bass sounds good too...
Author:  norskmetall [ Thu Feb 17, 2011 11:04 am ]
Cool to see others loving the Quad !
I have definitely reached my goal with my Quad, thats for sure; That same sound from the Justice and Puppets albums.
For my part, to the extent that when I touch the guitar or even the string noise occurs, it instantly reminds me of those albums.
I used the notes from Flemming, and since the guitars are dual and quad layered, the boost and cut with equalizing must be more than for only one guitar, i.e. +4db could mean even +8db in high treble boost.
Even if the poweramp (6550's) and Eminence V12 speakers aren't the same as the Marshalls and Mesas, it's still extremely similar I think.
Here is a bad picture, but you could maybe spot some settings.
Author:  JD [ Fri Feb 18, 2011 2:33 am ]
what are your eq settings on the parametric
Author:  norskmetall [ Fri Feb 18, 2011 12:35 pm ]
A bit hard to say exactly, the legends on the equalizer are very deficient.
But around +4db at 120Hz, -5db on 900Hz and +9db at 6Khz. Some of the variable Q's are widened more than deafult.
Author:  norskmetall [ Sun Apr 24, 2011 8:05 pm ]
http://www.youtube.com/watch?v=UBtNRcRHbRQ
Here is a very short clip I made!
Damn those software EQs screws up the sound. :shock:
Still working on the diffiucult mic technique.
Author:  Darth Bacelar [ Thu Apr 28, 2011 6:24 pm ]
I donĀ“t think so! You did a nice work ;) sounds pretty close to the original recording IMO.
Damn, I should try some of your settings hahahaha what tubes you use on the Quad?
Author:  ryjan [ Thu Apr 28, 2011 11:33 pm ]
Sounds really good!
Author:  Friedmett [ Tue May 10, 2011 4:53 am ]
I have neve changed my tubes but I have opend to check what type is in it.
Grove tubes all ower.
Some of them does sound like the need to be replaced.
Author:  mxr2000 [ Sun Jun 26, 2011 8:26 pm ]
Love to the Quad Preamp any more settings?
Author:  norskmetall [ Tue Aug 30, 2011 7:08 pm ]
http://fwrproduction.com/FWR_Produktion/Notes_1.html#5
Here are the notes from MOP and AJFA.
Now, anyone have the clue about the exact speakers they used ? G12-65, G12T-75, V30 ? :?:
Author:  screamingdaisy [ Tue Aug 30, 2011 7:33 pm ]
I think it was G12-65s for MOP and AJFA. The switch to V30s wasn't until the black album.
Author:  Jackie [ Wed Aug 31, 2011 5:34 am ]
Yessir.
Author:  norskmetall [ Wed Aug 31, 2011 1:10 pm ]
Yessir.
Darn! I only got V30, G12T-75 and eminence V12... :?
Maybe the 75' would be closest.. ??
Page 1 of 2 All times are UTC - 6 hours [ DST ]
https://www.phpbb.com/
