I have a 2019 MV I got recently. I replaced the reverb pan and that helped the reverb as the stock pan was not good. The newer pan brought the reverb more into the mix. I'd still like to be able to increase the wet amount of the reverb though. With the Mix for Channel 1 dimed it's still not enough for my tastes. Has anyone modded theirs?
Also, is it normal that the reverb is far less present when Channel 1 is in the Tweed setting? I tried another MV and it had the same issue so I'm assuming that is the case. Kind of a bummer.
