Equalize
Has anyone tried to further equalize their Mark V with a equalizer pedal?
  • Yes and I still use it.
    Votes: 1 9.1%
  • Yes, but no longer use it.
    Votes: 1 9.1%
  • No
    Votes: 9 81.8%
  • Total voters
    11
Yep. Had Source Audio Eq for Ch2/Crunch... tested also using it with ch3 but the built in GEQ worked best in that context.
Source Audio is the "new hotness"...hehe. I got an older DOD FX40b I've yet to try. I used it on an older amp, but since the Mark V sounds so good on it's own, I've never thought I'd need it again.
Good idea though! Don't have to use it over all channels!!
I use a MXR 10 band in the loop. I cut out some fizz and boost the bottom end but the mids are flat. I use the gph eq onboard the amp for the levels.
I believe this was talked about in a thread talking about Metallica's tone. They used an eq in the loop of their Mark 2 C+'s.
There you go:
https://forum.grailtone.com/viewtopic.php?f=33&t=65501&p=450510&hilit=Metallica+tone#p450510
Page 17 of this thread has more advice on using an eq in the loop. It refers again to Metallica's tone:
https://forum.grailtone.com/viewtopic.php?f=33&t=37145&hilit=Flemming+Rasmussen&start=240
