FX Loop light on my Mark V ON all the time
Discussion for the new Mark V
Bankim
Post by Bankim » Sat Oct 26, 2019 1:04 am
Hi guys,
I have a minor issue with my Mark V 90. The FX loop light on the right side of the amp seems to be ON all the time, even when the FX loop is not engaged . Has anyone faced this kind of issue before ?
When I DO engage the FX Loop , the light just gets a bit brighter. I don't have a tech nearby. Getting a little paranoid because I dont want anything to happen to this amp.
Pics below :
https://imgur.com/PWezZ9Z
https://imgur.com/8Nrsfxg
Mesa Mark V Head
2x12 V30s Custom
Digitech RP1000
ProCo Rat 2, DD 3
Guitars : EBMM JP6 Fully Loaded, Fender Am Stratocaster, Ibanez RG370DXL
domct203
Re: FX Loop light on my Mark V ON all the time
Post by domct203 » Sat Oct 26, 2019 6:57 am
Hi guys,
Pics below :
What happens if you hard bypass the loop? Do you have the rear selector switch set to ‘FT SW’ (foot switch)?
Is this a brand new amp?
Bankim
Post by Bankim » Tue Oct 29, 2019 1:07 am
Hi guys,
Pics below :
How can I hard bypass the FX Loop ?
I have it set to FT SW at the moment and I have had this amp for about 6 years.
Mesa Mark V Head
2x12 V30s Custom
Digitech RP1000
ProCo Rat 2, DD 3
jaslan
Post by jaslan » Tue Oct 29, 2019 6:26 am
There should be a switch on the back right beside the send/return jacks. Check your channel volumes first though because they become the “final” volume control for each channel because the Output and Solo controls are also bypassed.
domct203
Post by domct203 » Tue Oct 29, 2019 1:09 pm
+1
Also try the different FX Loop settings and see if they work correctly when the foot switch is not hooked up (Ch 1 only, Ch 2 only, etc).
This could also be a foot switch cable issue.
domct203
Post by domct203 » Wed Oct 30, 2019 10:54 am
Just checking in to see how you are making out with your MKV?
