Changing V1 preamp tube is risky
Discussion for the new Mark V
guitarsawicki
Post by guitarsawicki » Tue Jul 02, 2019 4:55 am
I changed the V1 preamp tube (put that huge cover back also) and it was not easy. After that only hum could be heard from the speaker. I removed the V1 tube and it looked fine. I put it back (but not that huge cover) and still no sound. I removed the chassis and it is ridiculous how difficult that was. Then I saw that V1 glass was broken and that white stuff was on the top of the tube. Then I changed V1 tube and everything worked again. I must make hole to wood underneath the front grill so that V1 changing would be easier.
Mark V 90W 2013 head
2x12 vertical metal grill 1995 cabinet with EVM12L and C90 speakers
Doubleneck Stratocaster
Jim Dunlop Cry Baby 535Q
Boss CE-2 Chorus
Boss DM-2 Analog Delay
Boss DD-5 Digital Delay
Boss HF-2 Hiband Flanger
Boss HR-2 Harmonist
Wayno
Re: Changing V1 preamp tube is risky
Post by Wayno » Wed Jul 03, 2019 2:06 pm
Very tricky job to change v1 without removing chassis. Even in the combo it's difficult.
Her highness the Veenus
(Mark V/V4 & V7 12AT7 Combo)
2 x 12 Vertical Cab
GSP1101
Gibson LP Studio with alnico ii pro
Schecter C1-XXX with emg 81/85 18v
Jackson Dinky XL with Duncan designed???
Sigma DNC-1STE
Bankim
Post by Bankim » Thu Jul 04, 2019 9:34 pm
I have not removed the chasis ever in my 5+ yrs of owning it.. here is how you do it.. for amp head only.
Step 1 : Turn the amp upside down and let it sit such that the tube sockets point up.
Step 2 : Remove all power tubes n rectifier tube
Step 3 : Reach in with hands and slowly pull out V1. Remember the pin spacing when you take out the v1 tube.
Step 4 : Put in the replacement tube with the correct pin spacing as when you took it out in step 3.
I remember seeing a youtube video on this. Let me put in a link to it later ..
Mesa Mark V Head
2x12 V30s Custom
Digitech RP1000
ProCo Rat 2, DD 3
Guitars : EBMM JP6 Fully Loaded, Fender Am Stratocaster, Ibanez RG370DXL
