Sound loss across all three channels
Discussion for the new Mark V
Ckocher
Post by Ckocher » Sun Jun 23, 2019 8:12 am
Hello all. Fired up the V and I have sound loss across all three channels. Barely audible. Could it be power tubes? Any and all help would be greatly appreciated. I love this amp and nailed the tone I had in my head. Thank you.
Wayno
Re: Sound loss across all three channels
Post by Wayno » Mon Jun 24, 2019 2:58 am
Hi, I would check your tubes first. Namely power tubes, but also check on the different wattage settings too. Also preamp tubes, mainly v1. If none of those works to narrow it down it could be a Jfet issue similar to what I had and that's definitely a tech job to fix unless your a brain surgeon with a soldering iron!
Her highness the Veenus
(Mark V/V4 & V7 12AT7 Combo)
2 x 12 Vertical Cab
GSP1101
Gibson LP Studio with alnico ii pro
Schecter C1-XXX with emg 81/85 18v
Jackson Dinky XL with Duncan designed???
Sigma DNC-1STE
Ckocher
Post by Ckocher » Fri Jul 05, 2019 8:28 pm
I changed my tubes out. No improvement. I’m in uncharted waters now.
Ckocher
Post by Ckocher » Fri Jul 05, 2019 8:29 pm
Wayno
Post by Wayno » Tue Jul 09, 2019 3:09 pm
Tech job mate, any service centers near you?
2 x 12 Vertical Cab
GSP1101
Sigma DNC-1STE
Markageddon
Post by Markageddon » Wed Jul 10, 2019 8:55 am
Seconded. If its not the tubes, not the fuse, then its bite-the-big-one time: Tech servicing.
Mark V
Mark V:25
Mark III (Red Stripe)
Ckocher
Post by Ckocher » Wed Jul 10, 2019 5:06 pm
Yep. Gonna have to go to the tech. 105 miles
Tucker44
Post by Tucker44 » Thu Jul 11, 2019 10:22 am
FYI I recently had a pre amp tube cause similar. I never could decide which tube was the culprit. I had started v4 because channel 2 sounded weak. then I ended up rolling several and thru that process had a loss across all three channels. eventually I must have changed the correct one because she sounds awesome again.. good luck.
Ckocher
Post by Ckocher » Sat Jul 27, 2019 11:14 am
I changed all power tubes and all preamp tubes. Brand new. No results.
Markageddon
Post by Markageddon » Sun Jul 28, 2019 5:31 am
Chassis removal time, then packing and addressing it, then a hopefully relatively short wait for repairs and merciful billing are in thine future for sure.
Mark V
Mark V:25
Ckocher
Post by Ckocher » Wed Dec 11, 2019 5:24 pm
Hello all. I had to take the old girl to a tech. 200 miles. Diagnosed with a bad circuit. However, she is fixed and it sounds bad ass! Dude did a great job and I’m glad to be on her again.
jb's 52
Post by jb's 52 » Thu Dec 12, 2019 11:31 am
200 miles!!! Good to hear you got 'er fixed!!!
Could you let us know who you went to in case others have similar issues?
Good, solid techs are hard to find!!
Enjoy!!!!
Union Down
Mark V Head
Roadster Head
2x12 Recto Horizontal
