guitarsawicki
Hello!
I believe that Mark V 90 W 8 pin din connector is just 7 on/off connectors and power for footswitch. So the pins should be: Channel 2, Channel 3, Reverb, Mute, FX loop, Solo and EQ. The ground is needed of course. So I have 8 pin din connector and I am planning to build a connector box to my pedal board. The connector box has two stereo jacks connected to Boss ES-5 CTL 1/2 and CTL 3/4 jacks. I could connect to Mark V chan 2, chan 3, solo and eq jacks, but I want to use 8 pin din cable. So does anybody know how the 8 pin din is connected? I could build a test bench but I don't know what happens if I connect power pin to say channel 3 pin.
RJM Mini Amp Gizmo and the 20 feet cable is about 400 €. I don't want to by that, because I think it's possible to build a connector box by using original Mark V footswitch cable.
I hope you understand what I mean. I can always try to explain this more clearly.
Cheers
David Sawicki
Cheers
David Sawicki
