Need to darken the clean channel just a touch...
Discussion for the new Mark V
griff3
Post by griff3 » Thu Dec 13, 2018 7:02 pm
I typically run my Mark V:90 in 90 watt mode with EL34s (Variac Power.)
For the clean channel, after much fiddling I've actually come back to the "generic" (not fat, not tweed) setting because it gets me closest to my Two-Rock and my CAA OD100 Classic+ clean tones - those are my benchmarks.
And while I'm not trying to get my Mark V to sound like those, I find that, even with the Treble and Presence way down, there is a high frequency in there I can't get rid of...
When I play clean, I really don't notice it, when I have to use it as a pedal platform, it's VERY apparent because the OD pedals that sound great with the TR or CAA sound like a can of bees.
I'm using Mesa stock 12AX7s, and my EL34s are Winged "C". I don't think the power tubes would create this sort of high frequency response, I suspect a preamp tube. But which one? And replace it with what?
This is my question to you fine people...
I do NOT use the Graphic EQ on the clean channel. I've tried, but I need the graphic on Channels 2 and 3, and the same settings simply won't work for channel 1.
Thanks for any suggestions you may have.
Markageddon
Re: Need to darken the clean channel just a touch...
Post by Markageddon » Fri Dec 14, 2018 4:25 am
Your V1 slot may like the Tungsol 12ax7 (Goldpin)
That works for me. Beautifully rounded. 12AT7 in V7 too.
Mark V
Mark V:25
Mark III (Red Stripe)
OldTelecasterMan
Post by OldTelecasterMan » Sat Jan 05, 2019 6:59 pm
Buy a guitar that has the tone you want through your amp.
See how easy that is. No need to change the tube. Perfectly justified guitar purchase.
Boogie F-30
Mark V
Fender Hotrod Deluxe
Two 2X12 Vert. Cabs.
Two 2x12 Compact Cabs.
Telecasters, Gibson Les Paul, Gibson Howard Roberts Jazz Fusion and many more.
https://www.mp3u.com/#artist/id=8321/tab=feed
Markageddon
Post by Markageddon » Mon Jan 07, 2019 6:06 am
/\ Or even just pickups... but if that doesn't do it.... the tubeswaps an effective option.
Depends if you're talking about amp-stage issues or guitar-stage, I guess...
Mark V
Mark V:25
mace
Post by mace » Mon Jan 07, 2019 7:48 am
OldTelecasterMan wrote:Buy a guitar that has the tone you want through your amp.
Love it! I am always looking for new "reasons" to get a another guitar.
Rankings: #1 Mark V head, #2a TC50 combo, #2b Rectoverb 25 head
OldTelecasterMan
Post by OldTelecasterMan » Fri Jan 11, 2019 11:40 pm
Darken the clean channel just a touch? Adjust the "Tone" knob... Or adjust the tone knob on a new guitar in the music store, buy the guitar and that can be your darker tone.
Boogie F-30
Mark V
