It is currently Thu Jan 24, 2019 5:52 am
Post new topic Reply to topic  [ 1 post ]
PostPosted: Mon Aug 13, 2018 2:42 pm
Hello!
I have an issue I think i have isolated and am looking for a second opinion.
Perceived Issue: When running the Effects Loop there is a loss of tone and power, sluggishness in the lows and a loss of some harmonics
Theory: V4 and V6 12AX7 need to be replaced
Testing:
Stripped everything down to Guitar -> Amp -> Cab (This includes 0ing out the Loop Volume, turning off reverb, etc)
Disabled Effect Loop by Toggle
Hard Set Channel 3 on back
Set Tone and Note Volume
Engaged Effect Loop Toggle and bring Master Volume up to match above step
I repeated this in all three channels in 45 Watt
Findings: Most notably in Channel 2 and 3, when engaging the Effect Loop I had the above symptoms and have come to the conclusion it is the Tubes. Looking for feedback that confirms or suggest an alternative I should look at.
Shut Up and Play
2009 Mesa Boogie Mark V Head #310 (EL34)
1986 Peavey 412M (Sheffield 1290's)
2010 Rectifier Cab (V30's)
2008 Schecter Jeff Loomis (EMG 707 Active, 18v Mod)
2012 Schecter Hellraiser Solo 6
