Mark V25 Head to Marshall's 1960av cab
Mikeyboyeee
Hey guys. Will be receiving my V25 tomorrow and picking up a 1960av which is mono /stereo 4 and 16 ohms. Best way to connect? Run in mono and use 2 cables and the 4 ohm outs or just go 8 ohm out into stereo 16 ohm mode?
Thanks.
If it is 4 ohm mono, maybe only run one cable to the 4 ohm jack on the amp. Or, does the cab have two
mono jacks? That would seem odd.
I’m not sure about the stereo bit because the Mark V only does mono.
