Angle Loss
- Joined
- Nov 14, 2014
- Messages
- 13
- Reaction score
- 0
Hey all,
I use my Mark V with the footswitch only, but am having a problem between the footswitch and the toggle for EQ.
-footswitch works normally
-there doesn't appear to be any bent or broken pins on the FS cable
-all functions on FS work
(on all channels):
-when setting EQ toggle up to "on" the toggle takes priority and I can't turn EQ off on FS (normal behavior)
-when toggle set to "FS" the FS works (normal behavior)
-when set to "O" (off) the footswitch overrides the toggle (abnormal behavior)
What would be causing this? It used to work normally, then it seemed like it wouldn't be consistent and now it doesn't work. I don't play the amp but every other month, so I really haven't been monitoring it. I've worked (as a hobbiest) on amps and don't have a problem opening it up and checking things if one of you can give me some clues, thanks!
(on all channels):
