Hi there
First post here - sorry if this has been asked before. I searched and haven't been able to find anything on the troubles I'm having.
I recently acquired this amp secondhand. Sounds amazing but the noise is ridiculous at times.
I've replaced one preamp valve but the fan noise is quite noticeable at all times on both channels. When using it to record the fan noise is evident in all tracks. Using the cab clone feature straight into a PA is also unusable.
I also have a Butler Tube Driver which has never caused an issue with other amps I have owned. Even though I have the gain dialled down on channel 2 and the Butler TD is really just giving a push to the signal it buzzes like crazy when kicked in...once again sounds terrible in the studio and live.
The fan sounds like it is working hard as soon as I switch the amp on. Is that normal? Other people have claimed their amps are dead silent on both channels.
I really need to find a solution to these issues ASAP.
Thanks so much for your time.
