Hi Guys,
quick question for you guys in the know.
i have a new Mark V 25 arriving at the end of the week.
i only have a 16 Ohm cab (2 x 8 Ohm in series) now the 25 doesn't have a 16 Ohm port
so am i best to connect the 25 (8 Ohm port) to the 16 Ohm cab or rewire the cab with speakers in parallel to 4 Ohm and connect to 4 Ohm port on the 25?
reason i am asking is that the manual says
"A 4 Ohm Load will work fine, but will usually sound a little “softer” and more scooped with less “punch” in the
midrange frequencies"
Any advice would be appreciated.
thanks
RJ
thanks
RJ
