Tiger1016!
- Joined
- Feb 7, 2014
- Messages
- 4
- Reaction score
- 0
I am looking for recommendations on alternative speaker options for a Mark V combo that I recently got. I love how the thing sounds through my 2x12 horizontal rectifier cab with Mesa V30’s, and I am looking to try to get close to that out of the open back combo as well. The amp came with the stock C90, and I already knew I was going to be replacing this before I even got it (sounds too honky/boxy for me).
The obvious option would be to go with the Mesa V30 in this as well, but there are the inherent differences with frequency response and balance with open back vs. closed back cabs. From what I have found so far through a little research is some of the Eminence options might be potentially better option for this application but I am not sure which one might be a good fit or if there is something else that could potentially be even better. I would greatly prefer something that is an easy drop in without needing any modifications.
I am particularly looking for a focused and aggressive low-mid grind with good punch first and foremost. Also, I want a full and rich low end that is not muddy/boomy. Finally, I want a balanced upper-mid and high end that is not shrilly or too laid back. I play mostly 90’s to early 2000’s hard rock/alternative kind of stuff (Stone Temple Pilots, Foo Fighters, Chevelle, Muse, Smashing Pumpkins, Incubus, etc.), so I am mostly using medium to high gain tones but not into metal territory.
I don’t expect an open back cab to get me 100% to where I want to be, and I’ll be able to stay hooked up to my recto cab ~75% of the time (if I need to). I really only plan to use the combo cab by itself at relatively lower volumes around the house (no gigging or recording, but I do think that I crank is pretty loud for home use). So something that can be driven pretty well with a little speaker breakup, a decent bottom end, and good punch and definition at these kinds of volumes would be ideal.
Does anyone have any interesting recommendations for what might work well for this type of application? Thanks.
