MARK FIVE 25 TONE SETTINGS THREAD
Discussion for the new Mark V
Markageddon
Re: MARK FIVE 25 TONE SETTINGS THREAD
Post by Markageddon » Wed Jul 19, 2017 7:46 am
mace wrote:
Markageddon wrote:
orionz06 wrote:Differences? Any threads here? Search doesn't help with three characters.
http://forum.grailtone.com/viewtopic.php?f=33&t=73352
In this thread you can track the evolution of this discovery. Bandit was the 1st one, using this technique on the bigger amp. I just applied it to a similar gain stage in the 25. 35s should work with the same trick.
APEMAN was the first to try the AT7 in V6 and to post the idea of the AT7 (at least the first one I've seen in the past year). Then Bandit got very interested and did V4 and it took off from there. This was with a 90W Mark V.
Mace
OMG Quite right. Sorry about that mix up Apeman. fixed. Thanks Mace.
Mark V
Mark V:25
Mark III (Red Stripe)
Jfriley
Post by Jfriley » Wed Jul 26, 2017 1:30 pm
Thread detailing all you need to know.
Tube swap: Bigger more grinding mids, low end, increased useable gain in channel 2, smoothening out any offensive highs even in high gain mode, with high presence even.... , enhanced smoothness and sweetness in lead notes....
All from putting a 12AX7 in the V2 tube position instead of the AX7.
In this thread you can track the evolution of this discovery. Apeman was the 1st one, using this technique on the bigger amp. I just applied it to a similar gain stage in the 25. 35s should work with the same trick.
Hi, thanks for this. I've owned the v:35 for about a year and I'm still tweeking it (it lives at my drummers house so I don't get to mess with it often).
Is this mod easy to do? I have zero skills when it comes to this stuff. Where do you even order the tube from? If it's a quick pull out one, put in the other, and I can't damage the amp, then I may give it a try.
Markageddon
Post by Markageddon » Thu Jul 27, 2017 5:48 am
I just bought the Mesa 12at7 at my local tube stockists. You can order them at your local guitar store if they don't carry them. They're pretty standard, used for different roles in different amps. I would assume your local Mesa dealer is for sure.
If all else fails google 'Mesa 12At7 prices' and your county/city...that should yield results.
Paid £22 each uk money for mine. I bought 2.
Its as simple as a tube swap: Making sure your amp isn't plugged in to power, that its switched off, opening your chassis by undoing the 4 big screwbolts on the top of your amp, gently sliding out and turning over the chassis,
And replacing V2 positions' 12AX7 with your newly acquired 12AT7. (Its standard action pulling out/plugging in tubes. If you're not experienced, consult the many tubeswap guide vids on YT.) Re-assemble.. et voila. 8)
Consult the manual as to the location of the V2 socket. Its next to one one of the transformers, the PT, IIRC.
I'd say you'll be ok. I'm not Mr.Experience with the complicated stuff, and had only done 3 tube swap sessions in my 7 years of Mesaness. If I could, I'd reckon you could.
Heres a vid on the daddy amp which should illustrate the tube removal stuff. With the chassis out you'll not have to poke around to access the tubes. Dont touch anything else the other side of the chassis, the guts of the amp.
https://www.youtube.com/watch?v=QbhAYpjJrrw
Remember 2 points: as you're sliding the chassis out, to watch for the reverb wires that connect chassis to reverb tank. unplugging one of them may give the you the room to turn the chassis over. Reconnect it when you put the chassis back in, if you do.
Also that if your AT7 is like my two, the pins on the tube, from new in box are slightly angled in uniformally towards center. just take usual care in putting it in, line up the pins with socket, the no-pin gap on the tube with the bit of the socket holes where there are no holes. When there, It feels like theres resistance, but the pins will play ball as you gently yet confidently apply pushing in force. After that they're straight when you take em in or out.
Thats about as complicated as it gets. Hope this helps. :)
Mark V
Mark V:25
Rectifried
Post by Rectifried » Thu Jul 27, 2017 3:33 pm
Thanks for posting this :) Although I was under the impression you could access the tubes just by removing the front grill?
My 12AT7 Mesa tube is on it's way. Can't wait to try this out.
Mark V:25
Mesa Mini Rectifier
Mesa TA30 2x12 combo
Markageddon
Post by Markageddon » Sat Jul 29, 2017 4:17 pm
You're most welcome.
When I tried, I encountered solid board. Had to go for Chassis out. You want hand room anyways. Don't worry. You're gonna be fine. Thrilled to hear it. You'll soon be swimming in enhanced awesomeness.
Mark V
Mark V:25
Rectifried
Post by Rectifried » Sat Jul 29, 2017 6:56 pm
Markageddon wrote: You're most welcome.
Amazingly the tube got here in 2 days, free shipping from Sweetwater to California. Got it in and it is just as you described. Enhanced awesomeness :) Unfortunately I don't have my cabs here at home so will have to wait a week or so to try it out with the band. But going thru my Hot Plate into my computer I instantly could hear the difference, and the extra usable range on all the knobs, especially in 2c+ mode which is my favorite. Having that extra bass is awesome. And it may be my imagination but it feels like false harmonics are even more effortless than they were before...
Thanks so much for this mod...
Oh, for anybody else looking to remove the chassis - I had a little bit of a hard time with sliding mine in and out - turns out there was an edge of the tolex wrapped pretty far inside the shell that made it an extremely tight fit. But once I figured that out it was no problem, didn't even have to unplug the reverb wires as there was enough slack in them for me to reach the V2 spot easily. Oh, and I did this by having the head standing sideways, one end up, the other on the ground.
Ok, back to playing. :mrgreen: :mrgreen: :mrgreen:
Mark V:25
Mesa Mini Rectifier
Markageddon
Post by Markageddon » Sun Jul 30, 2017 4:06 am
Congratulations...!! Great stuff...!!! Again you're welcome and Im happy for you that you took the step forward.. :D
Its not just your imagination: everything will be/has been enhanced... even enhancing the sounds available now via Cab Clone, now that a lot of the excessive fizz at high gain has gone. Allowing you to use full gain and perform different pre-EQ feats, or hang with the thicker, smoother low gain sounds now on tap...Yes IIC+ roars. And yes the new bass is off scale awesome and Mark IV mode (basically feeling like IIC+ Pull Deep) takes the bass further. And Extreme has similar levels of bass but is everything is way more in your face, Mids, beautiful, clear, usable un-thin Treble etc Try full Mid, Bass 1'Oclock, Treble 5 O'clock, Presence 2 O'clock- full. (Then try same sound but Pres 11 o'clock) V shape or M on the graphic.
That should show you a bit of what this things capable of now.
You have only heaven ahead of you when you connect to a cab.
You'll be grinning for weeks/months/years....basically whenever you plug in.
Mark V
Mark V:25
Dreamtheaterrules
Post by Dreamtheaterrules » Fri Aug 04, 2017 11:41 pm
I did the S&M version of the tube swap (although I'm not normally into that). I read here before that you could swap preamp tubes on the V25 by removing the front panel. I'd swear I read of from Authorized Boogie! But I encountered solid wood that wouldn't move even with those screws removed also. Then on to the S&M method, which I DO NO suggest. It took me almost 30 minutes to get the old tube out, new tube in and tube retainer back on. I will NEVER try this again without just unbolting and sliding the amp out of the case. Rectofried replied to my email about 10 minutes after I was done. If I had waited for his reply I would have had a much easier time swapping V2.
Worth the trouble though! Can't wait to get home and try it more.
Mesa Boogie Mark V, Mark V25, PRS Archon, PRS Custom 50
Markageddon
Post by Markageddon » Sat Aug 05, 2017 7:15 pm
Dreamtheaterrules wrote:I did the S&M version of the tube swap (although I'm not normally into that). I read here before that you could swap preamp tubes on the V25 by removing the front panel. I'd swear I read of from Authorized Boogie! But I encountered solid wood that wouldn't move even with those screws removed also. Then on to the S&M method, which I DO NO suggest. It took me almost 30 minutes to get the old tube out, new tube in and tube retainer back on. I will NEVER try this again without just unbolting and sliding the amp out of the case. Rectofried replied to my email about 10 minutes after I was done. If I had waited for his reply I would have had a much easier time swapping V2.
Yes chassis out, every time for this procedure for sure.
Still....you know now. And you're fully prepared to rock. Have fun. \m/
Mark V
Mark V:25
Dreamtheaterrules
Post by Dreamtheaterrules » Sun Aug 06, 2017 1:21 pm
I am still curious though. Authorized Boogie posted that you could swap tubes on the V25 by removing the front panel. 4 Screws, and Boogie panel removed, shows another board and 4 more screws. Removed all 4 and can't BUDGE that board. Pried as hard as I could without damaging something.
Anyway, yes, ready for next time.
Markageddon
Post by Markageddon » Sun Aug 06, 2017 11:50 pm
With a Dremel maybe.... hahaha :p If you find out how to do it, let me know.
In the meantime, no matter the explanation, this may be a time to trust in your own (and my) experience.
Its not that much of a job doing the top bolts/chassis slide.
Maybe a good thing that its solid, structurally speaking really.
Mark V
Mark V:25
RoadDog
Re: MARK FIVE 25 TONE SETTINGS THREAD - Dumble Tones?
Post by RoadDog » Sat Sep 16, 2017 12:20 pm
Not sure if anyone has seen this but I think it is pretty cool ... I didn't imagine using the Extreme channel this way:
http://www.tdpri.com/threads/mesa-mark- ... re.678163/
Dreamtheaterrules
Post by Dreamtheaterrules » Fri Sep 22, 2017 3:55 pm
I'll be trying that this weekend!
Dreamtheaterrules
Post by Dreamtheaterrules » Sat Sep 23, 2017 12:07 am
FYI, those settings are VERY nice! But (maybe because it's a Tele forum) I needed a bit more treble or presence. The pic posted was low volume. Turning the master up really opens the amp up and fills out the lows so some more treble or presence was needed when I tried it with my PRS NF3.
This is great though. A little more gain and/or a switch to MIV and it REALLY sings. As mentioned in the linked thread, Santana tones are a few minor tweaks. This IS pretty cool. Thanks for posting it.
homesick345
Post by homesick345 » Sat Sep 23, 2017 3:28 pm
RoadDog wrote:Not sure if anyone has seen this but I think it is pretty cool ... I didn't imagine using the Extreme channel this way:
Yup; I created that thread/setting - & today made a track of the setting - using only my phone to record & my stereo for backing track, shooting for a Dumble / Robben Ford live sound
No pedals no editing no nothing :)
https://soundcloud.com/homesick-hanes/slow-dumble
