scott7d
Whenever my FX loop is bypassed (using master volume only), the amp is quiet as can be even at high volume/gain settings. Very little humming or feedback. When I activate the FX loop, I start to get some noise problems. The more I turn up the output on the front of the amp, the worse it gets. I've tried giving it more master volume and dialing back the output, but then I cant really get it to "gig" volumes unless the output is at 9 or 10 o'clock. The noise is there even if no pedals are active. Could this be a tube issue? I am stumped since the amp is so quiet when not using using the output and loop. I am not playing at extreme levels either. Mainly small to medium venues. I bought a Voodoo Labs power supply and that did not help either.
I'll try to explain more the best I can if anyone has some ideas I can start off with.
