Okay, so I'm an obsessive compulsive scientist type and I need hard facts or measurement. I decided to measure the power output of the amp via a couple of different methods.
Method one:
1. Attach a multimeter across the speaker terminals, set to AC volts.
2. Take note of the peak voltage on the meter as I play at my desired volume.
3. Convert to watts by watts = volts^2 / ohms
By this method, I'm putting out about 21 watts peak on any given channel at the volumes I'm playing. Interesting.
Method two:
1. Take amp to amp tech, who tells me that my previous method is okay, but his method is more accurate.
2. Hook up to resistive 8 ohm load, bypassing speaker.
3. Tone generator at 1KHz into front of amp.
4. Adjust volume and gain on clean channel to a non-distorted signal. i.e. - sine wave, non-clipped
5. Measure voltage on oscilloscope, x ~0.7
This method shows the amp putting out 60 watts RMS, non clipped.
So, I ask the amp tech....what does this RMS method tell me about whether I can run a V30 in the amp safely on the 90 watt settings? His answer? "It sounds great using the C90, I wouldn't change a thing." :roll: Which isn't what I asked him, of course. I left there just shaking my head a bit and being thankful he didn't charge me for that advice.
So I got home and messed with the amp more. Got settings that I really, really liked on each channel. I mean loved. I couldn't stop playing. Then decided to hook it up into my 212 vertical recto slant with V30's, bypassing the internal speaker. It was...just okay. Tweaked more, realizing the that C90 is going to sound different, as is the open back cab, and that I need to tweak for the V30. Still not liking it as much. What gives? I like my 212 recto cab just fine...more than fine, in fact, with my Express+ 5:50. Love it with that amp.
So I took off my scientist hat and put on my musician hat and plugged the C90 back in. Played for almost an hour, just digging the crap out of the tones I got.
You know what? This whole investigation is pretty much for naught. I ended up preferring the C90 in the open back light years over the V30 in the closed. And I was so sure I'd love the V30 like I do with my other amp. And I don't.
The amp tech was right. The amp sounds great with the stock speaker, don't change a thing. So, anyway, the technical analysis above might point to the fact that it's perfectly okay to run the combo with a V30. But the musical analysis, at least for me, says Mesa put that C90 in there for a reason. Don't change a thing.
