rabies
is it running in Class A or AB? the manual shows it's using two power tubes next to each other (1 and 2 or leftmost and next to it).
rabies said:45 WATT (EXTENDED CLASS A, PUSH-PULL)
So is it really class A in 45 watts? what is "extended" class A? Is that class A/B?
rocknroll9225 said:rabies said:45 WATT (EXTENDED CLASS A, PUSH-PULL)
IIRC, "extended" class A = fancy terminology for class A/B
rabies said:i have a feeling i may end up selling the M5 (too soon to tell but that's my gut feeling) and keeping the Rivera and Stiletto for now. I just wish the stiletto had more of that marshall bite/grind/crunch/bark. I need to try the Marshall JVM as well...
mule#1 said:rabies said:i have a feeling i may end up selling the M5 (too soon to tell but that's my gut feeling) and keeping the Rivera and Stiletto for now. I just wish the stiletto had more of that marshall bite/grind/crunch/bark. I need to try the Marshall JVM as well...
The JVM is nice. I tried it. Probably the best Marshall to date. My concern is the amp seemed noisy and you definitely don't have the control you have with the MK V.
Did you try the crunch on channel 2 of your V? Crank up the gain to 3 o'clock and the treble to 3"oclovk and you have a hot rodded JCM 800! That is very close to the JVM IMHO.
Enter your email address to join:
