Vogelsong said:I got to use my G50 relay today for the first time.
I noticed it really brightened up the tone to the point that it desperately needed to readjusting in the tone stack and eq.
domct203 said:Vogelsong said:I got to use my G50 relay today for the first time.
The Relay manual should explain this. Use the "Cable Tone" feature, that is what it is for.
Dom
Dom
BluesRock said:So, do you notice any decrease in sustain, or fullness off tone? I have a Shure system that is pretty good, but I definately notice a loss of sustain, and brightening of tone. Also a slight loss in fullness of tone. The brightness I can compensate for for the most part, but not the sustain or fullness to tone. As advertised, the Line6 is supposed to have no signal loss or loss of sustain, do you find that to be true?
Wow, this is a great point, and I'm sorry I didn't address it in my comments earlier.Vogelsong said:BluesRock said:So, do you notice any decrease in sustain, or fullness off tone? I have a Shure system that is pretty good, but I definately notice a loss of sustain, and brightening of tone. Also a slight loss in fullness of tone. The brightness I can compensate for for the most part, but not the sustain or fullness to tone. As advertised, the Line6 is supposed to have no signal loss or loss of sustain, do you find that to be true?
I messed with the g50 more last night. The brightness that it adds for me does not go away with the cable length knob. The knob does have an affect on the tone for sure in that it darkens the tone more and more with each turn. However, within this I can still hear the bright metallic tone when I strum the guitar. It isn't as bad as if it is on 0 but it's still there none the less.
Now I had it sitting on top of my amp and it was connected with only a foot long cable. So I decided to put a full length 15' cable on it to see what that would do. That then did the trick combined with the cable lenght knob the bright tinty tone went away completely.
I don't notice any loss in fullness of tone or sustain for that matter. Those aspects to my ear really don't seem to be affected especially once it's hooked up with a full length cable.
Enter your email address to join:
