I turned on the amp, and I will admit that I turned the standby switch on only a few seconds after turning on the amp which I never do. Why I did it this time I don't know.
I think I figured the mute button is going to get turned on immediately and I would tune up so it wouldn't matter. Usually it sits a little before I do anything but today I was running late.
Anyway, I took a few minutes to tune, turned off mute, and hit a few chords and then nothing. Pulled fuse, replaced it with ones I had leftover from the LSS and played for 2 hours with no problems.
So I have no idea what caused it. All the tubes appeared to be fine, no fireworks, I play on 45 watts at all channels so the rec tube shouldn't be an issue. For now I'm chalking it up to a fluke.
But I have to get fuses I think the amperage on the LSS fuses I have are lower than the one I pulled out of the Mark V. I have to check this.
