Drugs... are bad for you :roll:Jmango said:...I would go so far as to say that if you were to run your fingers across the guts with your eyes closed, it would feel the same too...
jvk said:Drugs... are bad for you :roll:Jmango said:...I would go so far as to say that if you were to run your fingers across the guts with your eyes closed, it would feel the same too...
And if you ran your fingers accross the guts, you'll no doubt get a very large electric shock from the filter caps :lol:
thegaindeli said:Looks like the inside of a $300.00 Kensington stereo. :mrgreen: End your tone quest, and go with a Mark IIC+ w/o EQ, and a Cornford MK50H II. Oh! Don't forget the Klon pedal.
phyrexia said:Those are my pictures. I posted them initially here:
http://forum.grailtone.com/viewtopic.php?f=33&t=37070
I think it's funny somebody sent them to you.
...have you played both?(a + with eq/..w/o eq...)..if you choose w/o eq, you must be none other than Doug West...and I am Batmanthegaindeli said:End your tone quest, and go with a Mark IIC+ w/o EQ
...you dont say?.....http://forum.grailtone.com/viewtopic.php?f=3&t=37701thegaindeli said:BTW - the MKV MK IV setting sound more like the MK IIC+ with eq... IMO.
The MKV's gain at 10 is around 7.0 on my Mark IIC+. I have way more control over the tone also - even without an eq.
pull some power tubes and sit the head on its end..allows for a better "angle for your dangle" when changing out v1,etchugsy41 said:Does anyone know how to get the chassis out of the head cab? I have tried a few times, unscrewing the top 4 screws, the side screws holding the power and reverb, and still no budging. Is this because of the bolt just below the transformer? How can I get the chassis out (it's quite hard to change preamp tubes without taking it out!)?
chris.
lesterpaul said:pull some power tubes and sit the head on its end..allows for a better "angle for your dangle" when changing out v1,etchugsy41 said:Does anyone know how to get the chassis out of the head cab? I have tried a few times, unscrewing the top 4 screws, the side screws holding the power and reverb, and still no budging. Is this because of the bolt just below the transformer? How can I get the chassis out (it's quite hard to change preamp tubes without taking it out!)?
chris.
Enter your email address to join:
