OFFICIAL MARK V TONE SETTINGS THREAD
Discussion for the new Mark V
tonedragon
Re: OFFICIAL MARK V TONE SETTINGS THREAD
Post by tonedragon » Tue Feb 11, 2014 7:45 am
barryswanson wrote:Why are people asking to have the settings thread emailed to them, aren't they reading it?
Sounds like spammers too me.
Or create account to view pics.
Or just fiddle around with the knob thingies in front of the amp.
DC3
MARKV Head
Soldano HR50
68' Bandmaster
Marshall cabs 2x12
guijs
Post by guijs » Sun Feb 23, 2014 11:11 pm
Hello,
I have a Mark V Combo and a Gibson Les Paul Standard. Could someone please post the closest tone settings for Metallica Black Album? I know that this was already asked in the past but I didn't found anything specific for my guitar.
Thanks in advance!
Mark V Head
1x12 Widebody Closed Back w/ V30
Main guitars:
'98 Gibson Les Paul Std+ w/ SD Slash
'02 ESP MX250 EMG 81/60
'05 Fender Strat Custom Shop w/ Fat 60's pickups
The_BoogieMan
Post by The_BoogieMan » Sat Mar 29, 2014 8:08 pm
If anybody is interested, I found a tone really similar to Parkway Drive. Settings are as follows:
Gain: 2 o'clock
master:9 o'clock
presence: 2 o'clock
Treble:3 o'clock
mid:3 o'clock
Bass: 2:30-3:00 o'clock
Triode
Mark IV mode
10 watt
EQ: sliders, as follows:
80Hz: All the way up
240: Bottom of slider on lowest line
750: Bottom of slider on middle line
2220: Balanced between the middle and top line
6600: All the way up
I'm using an ESP F-50 with Duncan Distortions, into an Ibanez tubescreamer and boss ns2 :twisted:
guijs
Post by guijs » Wed Apr 09, 2014 8:49 am
Does anyone have a setting for a Slash CLEAN tone? I have a Les Paul Standard.
Thanks in advance!
Mark V Head
Main guitars:
shorestyle
Post by shorestyle » Tue May 13, 2014 11:28 pm
This is a great Marshall-ish tone. I actually prefer this to my Marshall's. (JMP & JCM 800). Very full sound with plenty of sustain without cranking up the gain.
Channel 2
Crunch
No EQ
45 watts
Variac Power
Tube Rectifier
Gain: 10:30 o'clock
Master: Dimed
Presence: 10 o'clock
Treble: 3 o'clock
Mid: 10:30 o'clock
Bass: 9 o'clock
Zardoom
Post by Zardoom » Mon May 26, 2014 6:19 pm
Hi, as a new owner of a brand new Mark V, I was hoping that my endless quest for that Metallica MOP tone was nearly over, and I think it might be. I found these settings after a bit of research on the internet. The eq's are inspired by flemming rasmussen's notes, more so from the song "Battery"
Playing through 81/60 emg pickups
Chan. 3
Mark IIC+ Setting
CH 3 NORMAL
Gain 3.30 oclock
Master 10 oclock
Presence 10.45 oclock
Treble 2.15-2.30 oclock
Mid 9.45 oclock
Bass 8.30 oclock
Triode
EQ V
80hz bottom of the slider sits on the middle line
240hz 0 boost
750hz scooped equal to bottom line
2200hz top of the slider sits on the middle line
6600hz bottom of the slider sits on the middle line
now I tried these settings, and I thought gee... theres still quite a bit of mids here, but if i try to scoop out more with my MXR 10 ban eq, i'm gonna lose all my sound. Thats were I was wrong. By looking at Rasmussen's notes i tried it with the second eq and wow i was blown away. Here are the settings for the 10 band eq in the fx loop
125Hz about 4.5db boost
1KHz minus 6 to 8db, adjust to taste
4KHz about 6 to 9db boost
Still fiddling with the 1KHz and the 4KHz. They're really the key of the sound here
Every thing else sits at 0, including volume and gain.
With those settings the sound is actually more present even tho more mids are scooped out, pretty surprising.
Now keep in mind, I am not playing in a big room so my amp isn't set up ridiculously loud, but still. Might need a bit of knob tweaking if cranking it up big time. Anyway, tell me what you think if you wanna try these out. i think i'm on the right track here but any help or suggestion is appreciated.
Cheers
tele_jas
Telecaster - Twang - Rock - Metal
Post by tele_jas » Wed Sep 03, 2014 4:04 pm
So, after about 5 hours of playing around... This is what I've come up with for a Tele player that wants twang to metal. The GEQ is only used on Ch3, and it's a very nontraditional setting (not the standard V).
Channel one is pretty twangy with a hint of grit... I tried to mimic Brad Paisley/My Dr. Z to a point. Tweed mode
Channel two is a basic rock drive. Mark 1 mode
Channel Three is the one that was the hardest to dial in. With a single coil, it's hard to get a really heavy sound (and I wanted one). I know the treble is a key, along with gain, to get heavy... But with a single coil guitar/tele, you're already pretty bright. So I compensated by killing the highs with the GEQ and turning them up on the channel to push that gain. This sounds pretty good in all 3 modes, but I like the darker "Extreme" mode best so far. I'm still playing around with it and haven't gigged with these settings yet, so they're bound to change.
Dr. Z Maz Jr Mk.II * Dr. Z Stingray * Mesa TA30 * Some Telecasters ** EVH * Wolfgang * Bunch-O-Pedals!
tele_jas
With a Telecaster
Post by tele_jas » Wed Oct 08, 2014 12:47 pm
Mesa Boogie Mark V 1x12 combo with an Eminence Governor. Guitar was a Telecaster with a Lindy Fralin Blues Special single coil pickup.
With the lead:
https://soundcloud.com/tele_jas/markv_rock_lead
Rhythm only:
https://soundcloud.com/tele_jas/markv-no-lead
Settings:
Mode Mark IV
kraftwerkd
Post by kraftwerkd » Fri Jan 02, 2015 1:47 pm
I've been trying to mimic Josh Homme's more recent tone, that kind of mid-heavy sound with very little in the ways of low and highs. The only problem I've having is it always sounds like there's too much gain, but ah well. It's getting close, this is just a rough starting point that I'm using.
Channel 1 Normal
Tweed
45W
Gain 12:00
Master 12:00
Presence 12:00
Treble 11:30
Mid 2:00
Bass 9:00
GEQ:
80Hz: Cut that sh!t right outta there if you're going for a Lullabies and onwards sort of tone, bump it up a tiny bit for the earlier stuff.
240Hz: Halfway between zero and unity.
750Hz: Just a bump below unity.
2.2KHz: Halfway between zero and unity.
6.6KHz: Unity.
I'm also using a Fulltone Full-Drive 2 Mosfet for any extra gain needed.
This is through a bass cab, so YMMV.
Mesa Boogie MKV
2x12 of some kind
ESP LTD EC-1000 w/ Seymour Duncans
Pedals by Fulltone, Voodoo Labs and EHX
Bankim
Post by Bankim » Sun Jan 18, 2015 10:26 am
Finally found a nice crunch tone on channel 2. This channel has been kind of a sore point since I got it but it def made me smile today. Inspired by JP's mv25 demo :)
https://docs.google.com/file/d/0B3YWxYS ... cslist_api
Mesa Mark V Head
2x12 V30s Custom
Digitech RP1000
ProCo Rat 2, DD 3
Guitars : EBMM JP6 Fully Loaded, Fender Am Stratocaster, Ibanez RG370DXL
Boognoob
Post by Boognoob » Sun Feb 08, 2015 6:22 pm
Been doing some EZdrummer shenanigans tone testing for a demo for a band im playing with.
https://www.youtube.com/watch?v=rFdKCoVuIME
Guitar was Gibson V with standard, passive pickups it was shipped with, tuned to dropped A with 11-56 strings.
Amp settings: 10 watt (triode), bypassed loop, full power.
One track IIc+ mode (left channel) and same settings for Mark IV mode (right channel) just flipped the mode switch.
Treb: 12 o'clock
Mid: Inbetween 8-9
Bass: Same
Gain: 2 o'clock
Master: Inbetween 8-9o'clock
Pres: Inbetween 3 and 4o'clock
80hz: Halfway between mid and top line
240: Level with the 80, but half a slider's width down from there
750: Halfway between middle and bottom
2200: Slider's bottom on the mid line
6600: Slider same as 6600, but bottom of slider level with the top of the 2200
SM57 on the dustcap of a Marshall valvestate 4x12's top left speaker virtually 'touching the cloth'. :p
It sounds real aggressive, in the room, live and achieved extra fatness with a little post eq in the lowend, and with low and high pass filters employed, touch of compression. (also experimented with copying those tracks to additional left/right with a tight room reverb.) The philosophy was tight and aggressive and add lows, rather than try to ram the reg lows down the sm-57. The two channels of combined mid gain sound huge, to my ear, when combined in the mix with the bass guitar and thudding kicks, sitting on the rest of the frequencies. May add a third track with the recto 2x12 on crunch soon too...
Leopold
Post by Leopold » Wed Mar 04, 2015 6:53 am
I am also now owner of a Mark V Head. Some of my friends plays Bogner Ecstasy . They say the MarkV has no low mids , and the Bogner Ecstasy would be full in tone.
who can help me I know it's a stupid question
Even my friends say the Exstasy have more gain. I do not care, I reserve the Mark V anyway.
Is that all true, or only envy? :?
regards Leo from Germany
don`t be too harsh with my english :wink:
Soundclip:
https://soundcloud.com/leopold-1/mark-v-solo-mark-4
https://soundcloud.com/leopold-1/mark-v-rht-mark-4
kraftwerkd
Post by kraftwerkd » Mon Nov 16, 2015 9:10 pm
I've been messing around with different tones in the rehearsal room, and came up with some nice tones.
Channel 1:
Fat, EQ On, Bold, 90W
Gain 2:30
Master 11:00
Presence 12:30
Treble 12:00
Mid 10:00
Bass 9:30
Channel 2:
Mark I, EQ On, Mark I Thick, 90W
Gain 3:00
Master 1:00
Presence 3:30
Treble 3:00
Mid 2:00
Bass 8:30
GEQ:
80Hz cut out most of this, leave the bottom of the slider at the top of the bottom line
240Hz leave this a little bit higher than 80Hz
750Hz slightly below unity
2.2KHz leave this at unity
6.6KHz a third of the way up to the upper line
I use these settings with a Stonedeaf PDF-1 as a treble boost, so if it's a bit dark, just bump up the presence on each channel. I rarely use Channel 3 so I'm not going to mention it here.
Mesa Boogie MKV
2x12 of some kind
romero_sl
Post by romero_sl » Mon Dec 21, 2015 4:14 am
Hello from Spain...
Could you sent me the 'Mark V Editable Settings' psd at lorezorro@gmail.com
Thanks a lot
enriquejdiez
Post by enriquejdiez » Tue Jan 26, 2016 11:05 am
romero_sl wrote:Hello from Spain...
Thanks a lot
Ehiiii lorezorro, si lo has conseguido, ¿podías mandármelo?
enriquejdiez@gmail.com
