OFFICIAL MARK V TONE SETTINGS THREAD
Discussion for the new Mark V
MesaGod666
Post by MesaGod666 » Mon Jun 22, 2009 6:50 pm
This thread shall serve as the official MARK V SETTINGS thread until Ned (or whoever) puts up a tone settings page on the Grailtone site.
MesaGod666
Re: OFFICIAL MARK V TONE SETTINGS THREAD
Post by MesaGod666 » Mon Jun 22, 2009 9:25 pm
Passive pups sound better in the V than active EMG's. That's for sure. So here's my, "Leper Messiah" tone:
Chan. 3
Mark IIC+ Setting
CH 3 NORMAL
Gain 1.5 oclock
Master 10 oclock
Presence 10 oclock
Treble 2 oclock
Mid 9 oclock
Bass 9 oclock
Output 10 oclock
Pentode
EQ V
80hz mid way boosted
240hz 0 boost
750hz scooped mid way
2200hz 0 boost
6600hz 1/3 way boost
Mesa Simul-Class 2:Ninety; JP2C, Mesa/Boogie OS Cabs
OFFICIAL REDSKY WEBSITE
REDSKY ON FACEBOOK
MarkIVwidebody
Post by MarkIVwidebody » Tue Jun 23, 2009 5:47 pm
MesaGod666 wrote:Passive pups sound better in the V than active EMG's. That's for sure.
Not when I get done with it......
www.myspace.com/rawdealplanetband
Mark V head #498
BC Rich Kerry King Signature Wartribe EMG 81/85
Schecter C-8 Hellraiser 8 string EMG 808
ESP LTD MH-400 EMG 81/85
2 Avatar 4X12 cabs with 2 V30's-2 GHT75's each
4406cuda
Post by 4406cuda » Tue Jun 23, 2009 6:43 pm
I am using Passive Pickups on a 1976 Les Paul
Channel One
Fat
Gain 9
Master Maximum
Presence 9
Treble 12:30
Mid 10
Bass 12
Bold
EQ Preset 2
Channel Two
Gain 11
Master 12
Presence 2
Treble Maximum
Mid 9
Bass 9
EQ Preset Maximum
Mark I Normal
Channel Three
Mark II C+
Gain 3
Master Maximum
Presence Minimum
Treble 2:30
Mid 9:30
Bass 11:30
Bright Setting
Triode
Slider EQ
80Hz Top Line
240 Middle Line
750 Bottom Line
2200 One Third above the bottom line
6600 Half Way above the middle line
All 90 watts and full power
Mark V Head
EVH 5150 III 50 Watt
1976 Les Paul Deluxe Standard
1977 Les Paul Custom
1978 Westbury Custom
1985 G&L Rampage
1993 Fender American Tele
2004 MIM Fender Strat - Heavily Modified
2011 Gibson SG Standard
PeeMonkey
Post by PeeMonkey » Tue Jun 23, 2009 6:54 pm
Do you guys think running the ch. masters high and lowering the master output is better than balancing the two? The way I have it setup right now is about noon on most of the masters and about 10-11:00 on the output. Wondering if there is a diff if I dime the ch. masters, and lower my output to about 9:00
I know in some amps this makes a difference.
MesaGod666
Post by MesaGod666 » Wed Jun 24, 2009 7:57 pm
PeeMonkey wrote:Do you guys think running the ch. masters high and lowering the master output is better than balancing the two? The way I have it setup right now is about noon on most of the masters and about 10-11:00 on the output. Wondering if there is a diff if I dime the ch. masters, and lower my output to about 9:00
If you like it loud then more power to you. You can get really good tone out of 9 o'clock on output and masters. You EQ and T/M/B will add (or subtract) the tone volume as you see fit.
REDSKY ON FACEBOOK
MesaGod666
Post by MesaGod666 » Thu Jun 25, 2009 8:55 am
John Petrucci's Mark V Settings with a moderate mid scoop.
H/T: jdurso
REDSKY ON FACEBOOK
4406cuda
Post by 4406cuda » Thu Jun 25, 2009 10:55 am
The channel masters are another gain stage. I like the way it sounds on Channel 3 when it is maxed out.
Mark V Head
1985 G&L Rampage
MarkIVwidebody
Post by MarkIVwidebody » Thu Jun 25, 2009 10:41 pm
90W extreme mode
typical V e.q.
presence 2 oclock
bass 9 oclock
mid 12 noon
treble 3 oclock
boosted with modified SD-1 pedal
BBE SonicMax NOT sounding too good
10 band e.q. not used
The IV and IIC+ modes just don't sound as tight and focused or saturated enough for me but extreme seems best so far........
Mark V head #498
ned
Site Admin
Post by ned » Fri Jun 26, 2009 7:10 am
Now that I'm actually home for a couple of weeks I'll get a settings DB up. Probably next weekend as I have no gigs.
gibson5413
Post by gibson5413 » Fri Jun 26, 2009 10:51 am
Crunch mode
90w
Knob settings (o'clock)
Gain: 4
Presence: 9
Treble: 3
Mids: 10
Bass: 8:30
Master Volume: 9
Preset Knob: 1 (EQ sliders off)
Output 2
Amps:
Mesa Boogie Electra Dyne 1x12
Kemper Profiling Amp
Atomic CLR Wedge
Bogner Oversized 2x12
Guitars:
Anderson Drop Top
Anderson Classic S
Anderson Bulldog
Anderson Pro Am
Anderson Raven
My Clips:
http://soundcloud.com/gibson5413
MesaGod666
Post by MesaGod666 » Fri Jun 26, 2009 11:54 am
ned wrote:Now that I'm actually home for a couple of weeks I'll get a settings DB up. Probably next weekend as I have no gigs.
YAY! :P
REDSKY ON FACEBOOK
MesaGod666
Post by MesaGod666 » Thu Jul 02, 2009 10:35 am
Metallica Black Album Tone
Mark IIC+ Setting CH3 Normal Switch
Gain: 4 O'clock
Master: 9.25 O'clock
Presence: 10 O'clock
Treble: 1.5 O'clock
Mid: 8.75 O'clock
Bass: 9.5 O'clock
Output: 9 O'clock
EQ ON
PRESET EQ ON
The parametric EQ on my MARK V still functions while the PRESET EQ is selected. So, my sliders are all at Zero except for 750 which is scooped all the way. Then the PRESET EQ is maxed out to the right at 5.5 O'clock.
EMG-81 Bridge
Sounds freaking awesome. I'll post a clip later.
REDSKY ON FACEBOOK
rispsira
Post by rispsira » Thu Jul 02, 2009 5:35 pm
Really?? man thats weird! (not in comparison to mine though because its still on the way haha)
Ok but does it apply to the third channel only?? else it will cause a HUGE problem.
Oh and if someone is using the graphic eq for other channels as well it will also be a big problem
By the way im talking about the graphic eq still working while having the thrid channel assigned to the contour preset..
That's interesting please give us more details!!
Noonoo
Post by Noonoo » Fri Jul 03, 2009 7:20 am
"John Petrucci's Mark V Settings with a moderate mid scoop.
H/T: jdurso"
As far as I knew JP has not been using the Mark V yet, according to folks on JP's site. Perhaps I am wrong. Where are these pics from?
PRS Tremonti(EMERALD GREEN,10 TOP,Quilt)
PRS Custom 24(Blue Matteo,10 Top,Quilt)
Ovation POS
Boss Delay DM-2
Mesa Boogie Mark V head
Mesa Boogie Dual Rectifier Head (3 channel)
Mesa Boogie 2x12 Vertical Cab
Dunlop 535Q Wah
Fulltone Mosfet Fulldrive 2
