Sound out of head!!!
Discussion for the new Mark V
jlapalme
Post by jlapalme » Tue Mar 24, 2020 9:46 pm
Hi,
I purchased recently a Torpedo Live in order to do some silent recording.
I also purchased the unit in order to get power clipping in a house setting.
However, for the first time, I noticed that even without a cab, my mark V:35 head makes sound when I crank out the master volume "as if" there was a mini speaker in the head. Is this normal ? If yes, can somebody explain why ?
Cheers,
James
MattxG908
Re: Sound out of head!!!
Post by MattxG908 » Wed Mar 25, 2020 2:18 am
What I think your hearing is the fan running inside your amp head. All MkV's have a small fan inside of them for cooling. On the MkV:35 and 25 they are always on. On the Mk V 90w there is a switch on the back to turn the fan off but it is recommended to always leave it on.
Mesa Mk V 90w Head - Mesa 1x12" Widebody Closed Back Compact Cabinet
Marshall JCM 2000 TSL 100 - Marshall 1960A 4x12" Cabinet
Mesa Nomad 55 1x12 Combo
Gibson SG - Gibson Les Paul Classic - Fender RW Strat - Fender MIM Tele + many more
Eevil
Post by Eevil » Wed Mar 25, 2020 7:47 am
Hi,
Cheers,
James
Hi.
The output transformer produces some noises always when the amp is in use and in higher power levels :)
Cheers
Current:
- Diezel D-Moll
- Express 5:25
- 2x12 Recto horizontal
- 4x12 Stiletto slanted
- 1x12 EVM Thiele
Gone:
- Mark III 60w/grx
- Studio preamp
- Roadster head
- Triaxis / 2:50
- Stiletto Deuce Stage 1&2
- CAA OD-50
- Mark V
mace
Post by mace » Wed Mar 25, 2020 8:19 am
You may be hearing the tubes themselves if you have stuff cranked.
Rankings: #1 Mark V head, #1b TC50 combo, #3 Rectoverb 25 head
jlapalme
Post by jlapalme » Wed Mar 25, 2020 10:24 am
Thanks for the replies
@MattxG908 and Eevil. I'm not hearing noise (yes there there is the fan), I'm hearing what I'm playing like if there was a cheap small speaker in the head.
@Mace. So the tubes can produce an audible reproduction of my sound when cranked ? If that good or bad ?
Cheers,
James
Eevil
Post by Eevil » Wed Mar 25, 2020 11:02 am
Cheers,
James
Is it like this?
https://www.thegearpage.net/board/index ... r.2055067/
Current:
- Diezel D-Moll
- Express 5:25
- 1x12 EVM Thiele
Gone:
- Mark III 60w/grx
- Studio preamp
- Roadster head
- Triaxis / 2:50
- CAA OD-50
- Mark V
PBGas
Post by PBGas » Thu Mar 26, 2020 4:17 pm
If you are using a Torpedo Live connected to your head and it is acting as a load without a cab connected, then YES...that is normal. It is what you will hear coming from the reactive load. I had this same sound when I had the Live unit as well. All good.
JP-2C - 212 horizonal - Axe FX III - Waza TAE - Fender CSx4
jlapalme
Post by jlapalme » Sat Apr 04, 2020 10:23 am
Great. Thanks.
